Old 04-01-2015, 01:28 PM   #1
cyberdelic
cyberdelic's Avatar
Drives: 2SS/RS L99, IBM w/ White Rally
50k maintenance
I bought my Camaro back in August 2009, and it's finally getting close to the 50k mark. Previously I've only owned 100k+ miles cars, so this is a new milestone for me to contend with. I know only it's a considered a good mark for some more serious maintenance.
I've been prodigious about oil changes, I replaced the HVAC air filter last year, and I'm 50% through a second set of tires. I'm not sure what to look into for this, though. Hoses? Belts? Fluids?
I would like to do two things in particular. 1) Clean the engine bay. I happen to have some Simple Green, which I've heard can be great if you know what you're doing (I do not). I imagine there's a guide out there somewhere, but I haven't found it. 2) For the last couple of years my brakes have been getting increasingly squeaky just before stopping, especially over the winter months. My braking power seems fine, though. Is it possible they just need some special kind of cleaning, or should I consider replacing some parts?
Any advice on any particular subject is appreciated.
2010 Camaro, IBM 2SS/RS w/White Rally Stripes, Sunroof
cyberdelic is offline   Reply With Quote
Old 04-01-2015, 01:41 PM   #2
Spec
Drives: 2010 Camaro 1SS LS3
Here's a good site that helps with this (just change your car type at the header):
https://www.driverside.com/service-s...-29742-49411-0
I'm coming up to 70K miles, and here's my schedule:
Service Details
Service due at 72,000 Miles
Action: Description Inspect Accelerator Pedal Inspect Wheels & tires Inspect Tire Repair Kit Sealant Inspect Radiator cap Inspect Radiator Clean Radiator Inspect Parking brake Inspect operation Neutral Saftey Switch Inspect Exhaust system Inspect Exhaust system heat shields Replace Cabin air filter Inspect Brake system Clean AC condenser Inspect Fuel system
Spec is offline   Reply With Quote
Old 04-01-2015, 04:21 PM   #3
Beemer
"Red Rocket"
Beemer's Avatar
Drives: 2010 Camaro 1LT
At 50k I had my transaxle and transmission (manual) fluids changed.
Beemer is offline   Reply With Quote
50k, brake check, engine bay, maintenance
