Old 04-02-2015, 08:49 AM   #1
david06851313
Drives: 2014 SS ashen grey
2014 camaro ls3 SS having trans issues, in the shop now..
Ok I have a 2014 SS RS camaro. Only options were RS package, short shifter and dual mode exhaust.
I bought it brand new. Zero miles. After about 100 miles(100 mile hwy home ride after buying it) it started to grind second gear and plus itself out of gear. Also when you push the clutch in for first gear it does a loud shutter noise when it releases. I brought it to the dealer 4 times for this issue and during other issues I told them to keep checking this. The car now has 20k miles.
Other issues
It's had steering column replaced do to tilt lever snapping off riding down the highway
In for blower motor and controls not working correctly right now
I called and started a gm case number about the trans while its in the shop for the blower motor. Now the manager of my dealer has called back and asked what to do. I told him pull the trans and figure out what's going on. He agreed now after gm had contacted him. So now I'm waiting. To see what they find and go from there.
david06851313 is offline   Reply With Quote
Old 04-02-2015, 03:14 PM   #2
david06851313
Here is what's going on. Said replacing second and third gears and syncros. They said both gears looked wore and needed replaced. Car has 21k miles.
Old 04-04-2015, 12:25 PM   #3
david06851313
Update, trans is fixed and seems to drive better then ever imo besides the clutch feel. On the bad side someone test drove my car or moving it around and bumped something with the nose. Bumper has a crack in it and paint scrape. Now dealing with that and hoping they claim fault and fix it.
Don't ever go to Hayes Chevy in North GA! Horrible! Search my name on here!
Old 08-18-2015, 02:06 PM   #4
david06851313
Well it's doing it again now.. And the clutch has felt mushy since they gave it back.. Haven't even put 600 miles on it yet.
Old 08-26-2015, 10:43 PM   #5
david06851313
In the shop again.. At a different dealer this time
Old 08-30-2015, 12:21 PM   #6
david06851313
Haven't heard a thing yet... Been since wed..
Old 08-30-2015, 12:58 PM   #7
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
The noise on pushing the clutch in while in first is pretty much normal, my 2010 does that if I am completely off the throttle and the drivetrain is loaded and push the clutch in quickly.
It's the driveshaft and slack banging around a bit, there really isn't much to do about that.
The popping out of gear and grinding sucks though, my 2010 has always had a grind going into second gear every once in awhile. I'm just ignoring it for now since it's random and will have the transmission rebuilt probably by Tick Performance once it gets worse.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 08-31-2015, 12:24 PM   #8
david06851313
It doesn't do either of those issues since it was rebuilt, it now just is notchy in second and the clutch just has no feel at all.
