Old 04-02-2015, 11:38 AM   #1
LDRX3
LDRX3's Avatar
Drives: White V6 camaro
Question Mylink non navi installation on a 2014 LS
Has anyone done an upgrade from the standard oem radio to the mylink non navi? I have the screen and the new receiver but I seem to be missing a few cords. (not exact part but same outputs) I'm not sure which I need so if you've done this installing please help!!
LDRX3 is offline   Reply With Quote
Old 04-02-2015, 12:52 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
check out gen5diy.
And regardless of NAV, I believe the radio has to be programmed to match the car (VIN).
JimE is offline   Reply With Quote
Old 04-02-2015, 01:24 PM   #3
jeffa
Drives: 2014 2LT/RS Ashen Gray Metallic
Originally Posted by JimE View Post
check out gen5diy.
That would be correct...
jeffa is offline   Reply With Quote
Old 04-02-2015, 02:16 PM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
check out gen5diy.
Thanks for the help, as to the programing, if they do it to your VIN it will not work, you did not have mylink so it will not know that its there.
member had one that was locked, add the rear camera, it worked with the screen locked and they went to the dealer to program to there VIN, but there car did not come with the camera, so as soon as the program was done no more camera.
Old 05-15-2015, 09:44 PM   #5
LDRX3
LDRX3's Avatar
getting to this post so late but thank you guys for the help!!
Old 12-13-2019, 12:42 PM   #6
CFeller12
Drives: 2015 Z/28, 1969 Z/28
Did you ever get it programmed? Can you just have them program it to the vin of the car it came out of to unlock it?
CFeller12 is offline   Reply With Quote
audio upgrade, camarov6, mylink, wiring help
