![]() Drives: 2015 ZL1 Silver Ice Metallic Manual Join Date: Oct 2013
Octane Booster for 91 octane California gas
Would love to get my hands on 93 octane gas, but I can't find any better than 91 octane.
What do other folks in CA use, how much, and how often? |
![]() Drives: something faster than you Join Date: Aug 2010
Don't bother, none of them will make any real difference. You might get 91.6 octane after using a full can of that stuff, not worth it.
Find some E85 or unleaded race gas around that you can mix in with regular 91 if you want higher octane. |
![]() Drives: 2018 Summit White Camaro 1SS Join Date: Mar 2014
Even Torco?
'18 Satin White Vinyl Wrapped 1SS, 6MT, Low Gloss Black Wheels, NPP Dual Mode Exhaust
Added: Diode Dynamics Black LED Sidemarkers, GM Dark Finish Tailights, GM ZL1 Black 3rd Brake Light, Black Plastidipped Bowties(front/rear), AFE Dry Drop In Filter, 12mm Spacers(front/rear) |
KaBoom1701
I use Torco.
Work great...no KR.
Mods:
Torco or boostane are both proven to raise octane as you can even see it in the tune, by the ability to add timeing. Over the counter boosters I believe are useless.
You can use these two to raise octane as high as 104. It does add about a buck per gallon of fuel cost. |
#6 |
How much do you add to 91. What octane do you shoot for?
#7 | |
![]() Drives: 2015 Camaro SS 1LE Join Date: Dec 2014
I use it too, works perfect. Have before and after logs showing KR is gone after filling up with shitty 91 octane. Kindly ignore anyone that claims Torco doesn't work. |
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Torco works great.
Nick
Corvette Z06 -1200ish rwhp |
#10 | |
KaBoom1701
Mods:
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Torco, especially during the summer. Terrible octane here! 76 station sells race fuel for around 9.70 a gallon.
#12 | |
#13 | |
#14 | |
KaBoom1701
Remember these cars are set up to run 93 octane from the factory to maximize HP and torq. Anything less is just wasting your money and driving pleasure with the ZL1.
Mods:
