Old 04-06-2015, 08:55 PM   #1
mikeyg36
Drives: 2015 Z/28 #533
Z/28 Jack Points
I'm about to do the first oil change on the Z and I just realized that the jack points that I use on my SS are covered by plastic. How is everyone jacking up the car?
mikeyg36 is offline   Reply With Quote
Old 04-06-2015, 09:06 PM   #2
macalot
macalot's Avatar
Drives: 1969 Z/28 + 2015 Z/28
There are two jack points on each side that are the pinch weld type. If you look you can see them where the areo is molded to expose the jack points. You will need a pinch weld adapter for your jack though, and a very low profile jack.
I think the manual shows a diagram, not sure.
macalot is offline   Reply With Quote
Old 04-06-2015, 09:41 PM   #3
mikeyg36
There isn't anything in the manual and I can't really see what you're talking about. I'll just check it out again tomorrow. Is there any way to jack it from the sides and squeeze the stands under it?
Old 04-06-2015, 10:34 PM   #4
brt3
Runs with scissors...
brt3's Avatar
Drives: '14 Z/28s SIM/SW
Besides the pinch weld jack points, here's something from the factory that goes into more detail:
brt3 is offline   Reply With Quote
Old 04-07-2015, 12:26 AM   #5
mikeyg36
That's perfect, thank you!
Also, does anyone know if the oil change process is the same as C6 Z06's dry sump system?
Old 04-07-2015, 07:05 AM   #6
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
oil change is the same as a C6 Z06. It has two drain plugs in the pan which are clearly marked with an arrow to make sure both plugs are removed. The plug in the normal position only drains about 1-2 quarts. The front plug drains the rest and be prepared for 8-9 quarts from the front plug which obviously drains the tank.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 04-08-2015, 07:13 PM   #7
mikeyg36
Dumb question guys, the right drain plug is directly above the aero and the frame. How am I supposed to drown it without oil going everywhere?
Old 04-08-2015, 10:01 PM   #8
Stephen12ZL1
Drives: '21 ZLE A10
take the belly pan off...oil still goes everywhere. There is a solid cross brace directly under the rear drain plug.
Old 04-08-2015, 10:04 PM   #9
mikeyg36
Yeah I noticed. I crammed a funnel in there and that minimized it
Old 04-09-2015, 12:06 AM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
http://www.zl1addons.com/index.php/p...5th-gen-camaro
Mods:
