Old 04-08-2015, 06:47 PM   #1
ZL1-V
Drives: 2013 Camaro ZL1
Racing Brake Carbon Ceramic brake kit
I was going to try and adapt a Z/28 CCR brake kit to my car. That would be all wrong since the calipers wouldn't match the car's designation. I found out that Racing Brake is starting to produce kits with CC rotors and pads! I visited the shop today and looked at what was available. They now have a kit for the Nissan GTR! Looked around and found the parts needed, spent time to spec out everything and once it's assembled together there will be one for the ZL1. I will warn you now not cheap by any means. Larger rotors for the front. Looks like it will need 20" wheels to clear. Pictures to follow once assembled.
ZL1-V is offline   Reply With Quote
Old 04-08-2015, 08:03 PM   #2
vicnkathy
Drives: 2014 Subaru Forester Turbo
That's going to be awesome
vicnkathy is offline   Reply With Quote
Old 04-09-2015, 01:40 PM   #3
ZL1-V
Here's the picture of the prototype kit for the Nissan GTR. The set that are being made for the ZL1 will look similar but without yellow calipers, and with a black hat instead of blue which is their standard order over the carbon disc. The calipers are red and forged aluminium. I believe the specifications are 395x36mm front carbon rotors and 390x32mm rear carbon rotors. Below is the Z/28 rotor and caliper. They will be similar to the look of the Z/28 rotor but without the Z/28 marking and won't be a Brembo sourced caliper since they have their own made by their own manufacturer.
Old 04-09-2015, 02:04 PM   #4
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
I imagine this'll be the setup to have once they come out with it. Looking at their website, the prices aren't bad for what you're getting, either.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out!
Burt is offline   Reply With Quote
Old 04-09-2015, 02:20 PM   #5
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Tell them they need to make drop in rotors for the ZL1 set up...
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 04-09-2015, 02:46 PM   #6
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Redlineviper is offline   Reply With Quote
Old 04-09-2015, 03:56 PM   #7
ZL1-V
Firefighter,Redlineviper,
That was the first question out of my mouth yesterday at the factory before they showed me the parts! Guess what the answer was?
Old 04-09-2015, 03:58 PM   #8
Firefighter
Yeah, I can imagine. Some of us don't think we need new calipers when we have Brembos already.
Old 04-09-2015, 04:01 PM   #9
ZL1-V
Check this out!
Weight of the assembled front rotor.
Old 04-09-2015, 04:11 PM   #10
ZL1-V
Which is funny as they had some of them (Brembo) sitting on the test bench disassembled. I tried mixing and matching everything there, even factored in a lower cost system that would be harder to source pads for when replacing but aimed more towards the "normal" driver that wants looks and performance, but not needing the extreme braking capability of the larger fronts. Now the engineering side takes over and a final product in 6-8 weeks assuming the other manufacturers and suppliers are without incidents that slow them up.
Old 04-09-2015, 04:39 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Very nice!
Mods:
Old 04-11-2015, 08:02 AM   #12
Sakudog
Sakudog's Avatar
Drives: 2019 ZL1 1LE A10
I'd go CF rotors & the correct pads, but never a total upgrade for my ZL1 because I don't track enough. If the CF rotor/pad combo comes out for the OEM brake system, well I'm buying it that day.
Ryker #29
2019 ZL1 1LE A10
2015 Z/28 #809
Sakudog is offline   Reply With Quote
Old 04-11-2015, 11:34 AM   #13
ZL1-V
Sakudog,
I heard that, I wish there was an OEM kit available! I got tired of waiting for one so decided to ask for help. I received a call on Friday informing me that the front rotors will be slightly larger than originally stated in the above post. I think he said 394! I will know more next week.
This should help with the ZL1's weight disadvantage on heavy braking into turns. I am expecting being able to use late breaking with more confidence.
Old 04-11-2015, 12:35 PM   #14
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
They really need to make the rotors where you can run the 19" rims. There is not a good 20" tire available that compares to the Hoosier R6 in 19". I'm getting my racing brake iron rotors so hot I'm warping them with stock calipers and racing pads....
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
