Old 04-09-2015, 07:14 PM   #1
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Drives: ‘13 ZL1, ‘17 TT ZL1, ‘17 Silverado
Tire noise and rear end howl??
I have a ZL1 and I'm hearing 2 different sounds. First is the cycling, low end rubbing/grinding, that sounds like it's coming from the passenger side. This only happens between 10-45mph. It doesn't matter if I'm on or off the brakes, accelerating or decelerating, or driving straight or turning. Also, the faster I go, the faster the cycling sound, and the slower I go, the slower the sound.
The second sound is a higher pitched howl coming from the rear and is audible mostly on cruising speeds, anywhere between 35-70mph, but only when I'm decelerating. As soon as I even touch the gas, it stops. It's not very loud, but it's noticable.
I took my car to the dealership and had a tech ride with me. The way he was talking, he seemed to be the guy that worked on the high end vettes and Camaros. The first sound he noticed was the cycling sound, which he immediately said, "That sounds like your tires." Could it be I have a flat spot or maybe something wrong? He couldn't say exactly, but he told me it is very unlikely that it could be the brakes or a bearing. He said as long as it doesn't affect your handling or traction, I wouldn't worry about it, and it should go away once you change your tires. I personally don't want to spend $300 per tire just to maybe find out that's what was wrong. What do you guys think?
The second noise he heard was the rear howl. He said it was gear lash causing this sound. He also said he doesn't think it would be warranty work (like changing the fluid) so I shouldn't bother with it, because it's not very loud and shouldn't affect anything.
Basically, I know both of these sounds are not normal, and I don't want to wait til they get worse or cause serious damage. What is everyone else's thoughts? Do you think those are the problems?
ZL W0N is offline   Reply With Quote
Old 04-09-2015, 07:51 PM   #2
ELIC1
Drives: black and silver
I would take it to a tire shop an see if they can check out the tire aND SEE iF THERE IS A FLAT spot in it. second I would change out the fluid. and se what happens, if this does not fix it I would try a different dealer
ELIC1 is offline   Reply With Quote
Old 04-10-2015, 11:03 AM   #3
i007spectre
i007spectre's Avatar
Drives: 2016 2SS, 2008 HHR ECTO-2H
I had rear end howl in my 2010 just like you describe, only when decelerating. They replaced my rear differential under warranty. The fluid was low and had tons of metal shavings in it, that's how I knew what the problem was. Mine was a V6 though.
i007spectre is offline   Reply With Quote
Old 05-14-2015, 05:09 PM   #4
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
I think I figured out what the cycling sound is that's coming from my front passenger side wheel. I jacked the car up yesterday and noticed an uneven tire wear. I checked to see if it was a bad wheel bearing by trying to rock the wheel back and forth. Nothing. I'm thinking my alignment is a little off because of the uneven tire wear, which is most likely what is causing that cycling sound. I'm thinking an alignment will help, but won't fix the noise issue because of the tire. When I eventually replace the tire, hopefully the sound will go away.
Old 05-14-2015, 06:46 PM   #5
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
yea the sound on deceleration sounds like it could be the diff. check the fluid and the pinion nut (if it has one).
maddoggyusa is offline   Reply With Quote
Old 05-14-2015, 09:29 PM   #6
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
When I get the alignment fixed, I'm going to have them change the fluid too.
Old 05-22-2015, 10:46 AM   #7
GM-ACE
Old school tech
GM-ACE's Avatar
Drives: Ruby 1LE - 2024 2SS 1LE
You have a differential issue. Fluid change with friction modifier might help, but when there's an issue with the gears, you usually have a coasting noise or an accel noise. Draining the fluid should tell you something based on how much metal comes out.
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51
Ordered 2024 Radiant Red 2SS 1LE
Ordered: 6/15/23 Accepted: 7/5/23
3000 - 7/5 ---> 3100 - 7/19
3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7
4300 - 8/14 --->4B00 - 9/5
DELIVERED 9/20!!
GM-ACE is offline   Reply With Quote
Old 05-22-2015, 10:51 AM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Know it's been a week, but the diff noise is a known issue on the ZL1 There is a TSB out for it. It involves several fluid changes and a driving procedure between each. Tell dealer to look up PIP5097 or TSB 3331992.
Old 05-22-2015, 02:19 PM   #9
ZL W0N
GuitarmageddonZL1
ZL W0N's Avatar
Yeah I read about the TSB on another thread. I'll be bringing it up especially if they try to charge me for it.
