Old 04-10-2015, 09:54 PM   #1
ramahl
ramahl's Avatar
Drives: 2014 camaro LS
supercharger & clutch?
just wondering should i upgrade my stock LS clutch. with the additional power i got coming, i just thought id ask. Ive never really been a clutch expert.
Are any of you guys riding with a new clutch? Also any input on stage 2 clutches is much appreciated
Hi, I'm Hendy and I own a Camaro
ramahl is offline   Reply With Quote
Old 04-10-2015, 11:59 PM   #2
gutterball
gutterball's Avatar
Drives: 2014 1LS M6 Supercharged
Send a message via AIM to gutterball
Clutch upgrade
Shortly after installing my IPF supercharger, my Clutch started to slip. Both Sycraft and myself went with the Ram dual clutch setup. We both like the Ram Cutch and it'll run you around $1100.
gutterball is offline   Reply With Quote
Old 04-11-2015, 08:18 PM   #3
ramahl
ramahl's Avatar
did the slip start bcuz of the supercharger, or was your clutch just old
Old 04-12-2015, 10:55 PM   #4
gutterball
gutterball's Avatar
I had approx 45K when I installed the supercharger and I never noticed the clutch slipping until the supercharger upgrade
Old 04-13-2015, 05:42 PM   #5
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
My stock clutch started to slip so I upgraded to a Spec Stage 2... which cracked after 2000 miles -__-
So stay away from Spec and upgrade to a Ram once you feel your clutch slipping. After the Spec blew I went back to a stock clutch assembly and it has been holding up very well, so no need to change it out until it starts to wear.
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
Old 06-17-2015, 08:00 PM   #6
ramahl
ramahl's Avatar
when you say slip what exactly was happening? im noticing a problem were if im at idle or stopping at a red light or stop sign my idle will be so low than my car shuts off!! wtf
Old 06-17-2015, 09:23 PM   #7
gutterball
gutterball's Avatar
That' not slipish. When you thromp down on the gas and it feel's like your tires are spinning and their not.
Old 06-17-2015, 10:27 PM   #8
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
FWIW, I installed my IPF kit 3-4k miles ago and clutch is still fine. I guess its a matter of if you get on it a lot and etc.
Lil' Nasty is offline   Reply With Quote
clutch, ipf, stage, stock, supercharger
