![]() Drives: 2013 1LT Join Date: Jan 2015
Part fell off??
Above is a part that fell of during an oil change and i cant seem to find any location as to where it goes. There are numbers on it that i would assume would be a tracer to its location or at least role it plays on being attatched to the vehicle. The part came off behind front driver tire the bottom fender region. The dealers can not seem to trace its origin as the numbers stampped only register to a part internal inside the engine which to me doesnt make sense (so much for certified chevy mechanics ) Any help is much appreciated as i am lost.
U.S. Army Veteran
Drives: 2LT/RS SGM M6 Polished 20's Join Date: Mar 2011
I know this piece. I had the plastic wheel well off early after I purchased my car. That, my friend is a spacer/insulator that fits between the fender and the bracing behind it to give a small amount of support behind the fender to prevent what some body men call "tin canning." The bend closest to your little finger on the second pic, goes up against the sharpest bend of the fender where it goes from horizontal to vertical. If you found it near the bottom of the fender, it would be because it fell from its upper position. If you remove enough of the fasteners in the wheel well, you'll be able to see where it fits vertically. (long edge against the inside of the fender.)
Hope that helps. Last edited by wadew2lt; 04-12-2015 at 03:59 AM. |
![]() Drives: 2010 CGM 2SS/RS M6 Join Date: Feb 2010
Happened to mine also. Took it back to the dealer(under warranty) and they fixed.
Mine was on the drivers side. They removed the tire. Removed screws from the inner fender plastic liner and pulled it back. Inserted the piece a the top of the fender, by were it meets with the door. ![]() Hope this helps |
Thank you all so much for your help. I am going to attempt this fix on my own since chevy is incapable of locating this sime fix. I'll reply back with how it went soon!! Thanks again!!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
I've had both fender liners out a few times. I've never seen that piece.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#6 |
376 cubic inches of fun
#7 |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
The part goes at the front of the front quarter panel right before the front bumper fascia. It's called a front Insulater. There is one on each quarter panel at the front end by the bumper. It's 18.59 MSRP.
It is NOT the one by the door, that one is much longer and thinner The part number is written right on the part, if your dealer can't find the part I hate to say it but they are just incompetent. Find a new dealer. |
#8 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Part 12 in the drawing. 2 per car. List price 14.87 each.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
#9 |
U.S. Army Veteran
Also, you'll find it goes just about straight up from the C (in CAMARO on the fender) which is slightly closer toward the door, not the fascia.
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
#11 |
Front quarter panel and rear fender...lol
Nice car bro!
