Old 04-12-2015, 11:12 AM   #1
tjames2014
Drives: 2011 camaro 2ss
abs,stabilatrack light on after gear change
Hi all well as the title states, I had the gear swap done over the weekend to a 3.91 in my 2011 a6 camaro.I have a sct-4 tuner and when I check for codes it doesn't show any , is there any other way to clear without going to a dealer.. thanks
tjames2014 is offline   Reply With Quote
Old 04-12-2015, 11:15 AM   #2
brokencilence
brokencilence's Avatar
Drives: '14 1LE, Z28.R
was the car re flashed for the 3.91 gears? If not it needs to be....
Far beyond stock....
brokencilence is offline   Reply With Quote
Old 04-12-2015, 11:21 AM   #3
tjames2014
I changed it with the tuner
Old 04-13-2015, 11:09 AM   #4
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Who did the swap? If a GM dealer did it, they would get new calibrations for the 3.91 gears and reflash any necessary modules.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 04-13-2015, 11:50 AM   #5
mp51998
mp51998's Avatar
Drives: Black 2011 2SS/RS
May have damaged a speed sensor while removing diff. There should be a code thrown for that tho.
mp51998 is offline   Reply With Quote
Old 04-13-2015, 12:37 PM   #6
tjames2014
I'm going to have it scanned this week to see what comes up . Dealership wouldn't do it here I had a local mechanic install them for me.
Old 04-13-2015, 12:45 PM   #7
tjames2014
I had a local mechanic do it here ,because dealership wouldn't do it. I'm going to have it scanned this week, I've also changed the ratio with my sct-4 tuner.
Old 04-13-2015, 07:54 PM   #8
tjames2014
Well after getting it scanned one code was right rear speed sensor. And after some more research it turns out those sensors will cause all kind of codes to pop up
Old 04-14-2015, 12:37 PM   #9
mp51998
mp51998's Avatar
They are not expensive and very easy to change out.
Old 04-19-2015, 08:28 PM   #10
tjames2014
Yeah I've priced them already ,gonna change it out this week
