Old 04-12-2015, 11:36 AM   #1
Raven87
C'mon- really?
Raven87's Avatar
Drives: Looking for a ZL1
No Lift Shift question
Does the car have to be in a certain PTM mode to use the NLS feature?
I couldn't find the answer in my manual. Thanks!
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD
Raven87 is offline   Reply With Quote
Old 04-12-2015, 11:38 AM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Yes.
PTM # 4 or 5.
# 4 with street tires.
# 5 with drag radials.
Mods:
Old 04-12-2015, 12:49 PM   #3
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
No. NLS works all the time. KaBoom is thinking of Launch Control. Launch control works in all the PTM modes. Not just 4 and 5.
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 04-12-2015, 03:04 PM   #4
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Both work all the time.
KLR ZL1 is offline   Reply With Quote
Old 04-12-2015, 04:07 PM   #5
ZO6 Bryan
ZO6 Bryan's Avatar
Nope. The launch control is only available in a PTM mode or if you have a convertible it's available when you put it into competitive mode.
Bryan 2018 ZL1 M6
Old 04-12-2015, 05:04 PM   #6
ZL1-V
Drives: 2013 Camaro ZL1
What Z06 Bryan typed earlier is what I have been going by. I just did NLS yesterday. NLS works well for me getting on the freeway on ramps at times when I need it. I watched it awhile ago but I'm pretty sure the video states you have to use the PTM modes to "activate" launch control?
ZL1-V is offline   Reply With Quote
Old 04-12-2015, 05:08 PM   #7
Gizmo
Gizmo's Avatar
Drives: ZL1
Every time I've tried NLS, it feels like the car is hitting the fuel cutoff. Actually feels like the car hesitates. Either I need to try shifting sooner or there's something else going on.
2014 BRM ZL1 #229
Rotofab, VMax, Moroso, MGW
I used to be schizophrenic, but we're okay now.
Gizmo is offline   Reply With Quote
Old 04-12-2015, 09:08 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Correct. My fault.
Mods:
Old 04-13-2015, 01:52 AM   #9
ems-pilot
ems-pilot's Avatar
Drives: 2016 Silverado
On the No Lift Shift, you have to be fast...its a rapid shifting and it is designed to keep the BOOST rpm's up. You may hit the rev limiter but its more about maintaining the boost in the supercharger.
There are some great previous posts that have video's attached to them...Look em up.
Topper
ems-pilot is offline   Reply With Quote
Old 04-13-2015, 06:32 AM   #10
Raven87
C'mon- really?
Raven87's Avatar
So - NLS is available any time (and you have to do it quickly and before the cutoff) but LC is only available in PTM (PTM 4 for street tires and PTM 5 for DRs).
Right?
Steve
Old 04-13-2015, 07:00 AM   #11
Tennis_pro
Drives: 2012 ZL1
Right?
Correct
Tennis_pro is offline   Reply With Quote
Old 04-13-2015, 10:09 AM   #12
Raven87
C'mon- really?
Raven87's Avatar
Originally Posted by Tennis_pro View Post
Correct
Thanks!
Steve
Old 04-13-2015, 10:21 AM   #13
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
What's the difference between NLS and LC?
winterboy8 is offline   Reply With Quote
Old 04-13-2015, 10:25 AM   #14
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
For a ZL1 with a M6 trans, no lift shift or NLS means that you do not need to take your foot off the accelerator when you go to push in the clutch to change gears. Launch Control or LC is a setting that will minimize wheel spin when you accelerate hard from a stand still.
