Old 04-16-2015, 08:03 PM   #1
M0dnar
Drives: 2015 Corvette 3LT with Z51
V6 Owners with GM Strut Tower Brace
Just trying to see if anyone is running into a similar situation as me. I bought a strut tower brace off another forum member, but when I went to install it on my V6 only 5 of the pre-drilled holes lined up. When I took it to the dealer they said they see it often and they usually need to enlarge the hole on the strut tower brace.
How many V6 owners who installed their own strut tower braces had to modify the holes on the brace itself for it to fit or was it truly bolt on for you guys?
M0dnar is offline   Reply With Quote
Old 04-16-2015, 08:26 PM   #2
ICTsccaCamaro
Drives: 2018 ZL1 1LE
Ours bolted up just fine on our 2012 RS
ICTsccaCamaro is offline   Reply With Quote
Old 04-16-2015, 08:31 PM   #3
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Mine bolted on no prob. 2011 v6
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
Old 04-17-2015, 06:26 PM   #4
rickwelch69
rickwelch69's Avatar
Drives: 2016 1LT RS Turbo 4
bolted in with no modification
rickwelch69 is offline   Reply With Quote
Old 04-20-2015, 05:45 PM   #5
sixt3denied
sixt3denied's Avatar
Drives: 2012 1LT/RS BLACK w NOS
Mine bolted with no problem. 2012 1LT/RS
BBK CAI, Dynomax Ultra Flow Exhaust, Vitesse Throttle Controller, 3M Dark Tint, BMR Subframe Connectors, BMR Drive Shaft Tunnel Brace, Bosch Brakes, Ny-Trex Triple Threat System, Glowshift NOS Gauge, Innovate LC-2 Wideband AFR Gauge, GM Strut Tower Brace, Elite Engineering Catch Can, Heritage Grill, Custom LFX Emblems, BAFX Bluetooth OBDII Interface, Torque Pro Logging, Big Worm Graphix Spears & Stripes,Niche M117 Misano Wheels, MGP Caliper Covers
sixt3denied is offline   Reply With Quote
Old 04-20-2015, 05:49 PM   #6
M0dnar
Thanks for the input guys. I'm going to fight for it under warranty then. They originally wanted to charge me to enlarge the holes on the brace itself.
Old 04-21-2015, 11:44 AM   #7
tdconner
Drives: 2014 Camaro LT RS in Red Hot
I have heard there are 2 different strut tower brace part numbers, never did get a clear answer on difference.
I had no problem mounting mine up on my 13 LS, or my 14 RS. What bolts are you using?
tdconner is offline   Reply With Quote
Old 04-21-2015, 12:15 PM   #8
M0dnar
The ones that came with the brace, it was bought from a member here who had no issues getting it bolted on.
Old 04-21-2015, 12:16 PM   #9
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
My 2012 2LT/RS bolted up just fine.
45thCamaro is offline   Reply With Quote
Old 04-21-2015, 12:58 PM   #10
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
my v6 vert came with one from GM and of course it was bolted up with all of the bolts to begin with
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 04-21-2015, 01:32 PM   #11
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Try threading in all the bolts by hand and then lifting the car to install the last bolt. Perhaps by making the car flex a bit, you can get them to line up.
Best regards,
Tyler
888-308-6007
Old 04-21-2015, 05:33 PM   #12
M0dnar
Pardon my ignorance, but is that good for the car? If the car sitting on a level surface isn't flexed like that wouldn't installing the brace like that either warp the brace/weaken it or force the chassis to remain in a flexed position?
I'm thinking the holes were just drilled improperly at the factory or the strut towers are positioned incorrectly.
Old 04-21-2015, 05:41 PM   #13
45thCamaro
45thCamaro's Avatar
I'm sorry to say this but, is it at all possible, that the car was in an accident, causing it to be off a little?
Old 04-22-2015, 12:43 PM   #14
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I had no problems installing mine on my 2013 ls
Jenner is offline   Reply With Quote
