Old 04-18-2015, 09:04 AM   #1
ValZL1
Drives: 2012 Chevrolet Camaro ZL1
Flow Tie (full emblem delete)
So I looked through a bunch of reviews on the emblem swaps and the folks who cut out the middle of the bowtie badge itself, leaving the silver edge. I was not really a fan of what I saw so when I got my badge off, I went ahead and removed the backer all around. The result looks pretty darn good. Took me about an hour and a half with a very sharp knife. The grille is still very sturdy and supported, no issues there. More airflow is definitely a good thing.
Driving around town, 62 degrees out, my water temp gauge didnt get past the 1/3 mark after 30 minutes of driving. Is that the typical range for the water temp or is it usually in the middle?
ValZL1 is offline   Reply With Quote
Old 04-18-2015, 09:10 AM   #2
cal45
cal45's Avatar
Drives: 2015 Blue Velvet Metallic ZL1
That actually looks like it is factory stock. Good job!
Pls post up some pics from a little further away
cal45 is offline   Reply With Quote
Old 04-18-2015, 09:13 AM   #3
ValZL1
Thanks! I'll try to snap one from far away but once you get far enough, it looks like it's all backed out pretty much.
Old 04-18-2015, 10:07 AM   #4
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Looks good.
Just remove that dam ugly front lic plate holder....
Mods:
Old 04-18-2015, 10:13 AM   #5
ValZL1
I would but it's riveted on and I dont want a bunch of poorly fitting bumper plugs on there. From what I've read, filling the holes and painting it looks good temporarily until the holes sink in a bit when the filler shrinks, making it look even worse. I cant afford a new bumper and full repaint right now.
Old 04-18-2015, 10:28 AM   #6
Expunge
Expunge's Avatar
Drives: 2013 ZL1 M6, '99 Tahoe 2Dr Sport
It would still look better with 4 holes in the bumper versus that.. trust me, freaking dealer mounted it on mine and I popped it out and it looks so much better.
Expunge is offline   Reply With Quote
Old 04-18-2015, 10:29 AM   #7
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
I had the holes filed in and painted on my Cobalt. I had it for 5 years after, daily drive in all weather and parked outside. It never shrunk or sunk or showed at all.
Flow Tie looks good!
2013 ZL1 #7860 is offline   Reply With Quote
Old 04-18-2015, 10:40 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Beside...what you gain in air flow from your bow tie delete you lose from that front license plate holder blocking some of your air ways into your lower front grill.
Mods:
Old 04-18-2015, 11:07 AM   #9
ZL1-V
Drives: 2013 Camaro ZL1
You car looks great with the emblem removed! I have to agree with the others, loose the plate as that is the main item changing your front aerodynamics. If you go to a GOOD body and paint shop where they use enough material, let it dry completely and then sand you shouldn't have "filler gaps".
ZL1-V is offline   Reply With Quote
Old 04-18-2015, 11:20 AM   #10
ValZL1
I'll take it by my paint guy and see what it says... maybe it will work would love to have it gone!
Old 04-18-2015, 11:34 AM   #11
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
How hard is it to do the float tie. Damn I like that look. Plate holes suck. When I bought my Z I told them if they mounted a plate bracket on there I wouldn't by the car.
Is there a thread for DIY float tie or flow tie, what ever it's called.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 04-18-2015, 03:17 PM   #12
ValZL1
For the flow tie, i used a screwdriver to pop out the bowtie. Comes out pretty easily. The backer is plastic. You simply use a very sharp knife, follow the bowtie lines and cut out the center. Not hard, just be patient and dont cut off a finger. Some parts of the plastic are thicker than others and the knife speeds up when it transitions. I had a close shave twice.. lol
Old 04-18-2015, 04:14 PM   #13
Ron_Robinson1
LoL thanks man I will def be careful
Old 10-08-2015, 11:30 PM   #14
L36L72LS3
Jersey Jeff
L36L72LS3's Avatar
Drives: 1969 Camaro L89/T400 ~ 2015 ZL1
Jersey mandates it...
Originally Posted by KaBoom1701 View Post
Looks good.
So, I'm just gonna take the tickets!
JerseyJeff
L36L72LS3 is offline   Reply With Quote
