![]() Drives: 2010 camaro ss/rs. Join Date: Feb 2012
rear diff
Recently had 3.91s put in my ss. Noticed gear oil smell. Put up on ramps. Suspect front seal? Is it simple to replace? Can diff be left in car? If not....cost?
Thanks |
Let me re phrase this.....has anyone done a front pinion seal in a 6spd ss? If so, can it be done without removing the differential?
![]() ![]() ![]() ![]() Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
In order to replace the seal you have to remove the pinion which means the lash and crush sleeve and all that stuff need to be reset.
I would just take it to whoever did your gears and see if they'll fix it. Ideally they should have replaced that seal when they did the gears anyway.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
#4 | |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
Drives: 2015 LFX Auto Join Date: Apr 2015
X3. Good advice and accurate!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Shops do replace diff seals with crush sleeves without taking the diff out. You have to count the number of pinion gear threads sticking out from the nut and mark nut and pinion gear so you put the nut back in exactly the same place; therefore, not changing the preload. The diff seal is about $15 from the dealer.
Where the wheels fall off this a bit is your supposed to use a new diff nut every time because you have to stake it. To do it without pulling the diff and resetting it up, you have to be willing to reuse the existing nut.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#7 |
![]() Drives: camaro Join Date: Apr 2015
