Old 04-19-2015, 09:03 AM   #1
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Fuel Pressure reading
Hello all!
I'm looking for some assistance. I have the Ultra-Gauge scanner, that I use to keep an eye on IAT's, STFTs, LTFTs, Fuel Pressure, Water temp, etc. I use ProSport standalone gauges for Boost and AFR monitoring.
In my tune, fuel pressure is commanded to 60.2psi for "normal", 65.3psi for "high flow", and 50.8psi for "low flow". Day to day operation, normal driving, the Ultra-Gauge reads 50.8psi. I know when I stick my foot in it, the fuel pressure increases.
Is 50.8psi "OK" for normal cruising around town driving? My fuel setup is the following: ZL1 pump, ADM FPCM, 65lb/hr injectors.
Thanks in advance fellow enthusiasts!
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 04-22-2015, 11:38 AM   #2
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
That's what the ZL1 FPCM programming is. You are fine.
Iam Broke is offline   Reply With Quote
fuel pressure, ultra-gauge
