Old 04-19-2015, 01:56 PM   #1
wirebender
wirebender's Avatar
Drives: 2017 ZL1, A10, White, sunroof, nav
Left front "popping" when turning right under more than light acceleration
anyone experience this and/or know what it is? Spent a day at dealership trying to figure it out...several techs involved....
did the rear diff fluid change, circles, figure 8's 3 times...that wasn't it.
Now it is also happening when taking off straight as well...under moderate to heavy acceleration...baffling.
wirebender is offline   Reply With Quote
Old 04-19-2015, 08:09 PM   #2
oldfriend
Drives: Fiat 500 E
Check lug nuts on that specific wheel
I would also lift the front left corner , and try to move the wheel left/right , bottom in/top out , and see if it sings like when driving , I'm thinking about some link in that wheel is giving up
Old 04-19-2015, 08:12 PM   #3
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
What are the Lag bolts?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 04-19-2015, 08:25 PM   #4
HDRDTD
Lug Nuts ?
Old 04-20-2015, 06:34 AM   #5
Mechzl1
Mechzl1's Avatar
Drives: 2013 Black ZL1
I notice this problem when backing out of my driveway. Never heard it any other time though. Curious to what it might be.
Mechzl1 is offline   Reply With Quote
Old 04-20-2015, 07:20 AM   #6
2013ZL1FUN
2013ZL1FUN's Avatar
Drives: 2013 ZL1 Convertible A6 BRM
I had experienced that noise also when backing out my driveway, but now after 2K miles it went away.
2013 ZL1 CONVERTIBLE BRM A6
OHIO
2013ZL1FUN is offline   Reply With Quote
Old 04-20-2015, 08:29 AM   #7
nivek
Drives: 2015 ZL1 Black #100
I am experiencing this also but it seems to be coming from the rear. I had mine at the dealership and after checking everything, they wrote it off to drive-train slack. I don't believe this since I have driven manual transmission cars most of my life. I guess I will wait for it to get worse so that they can figure it out.
nivek is offline   Reply With Quote
Old 04-20-2015, 09:42 AM   #8
wirebender
wirebender's Avatar
Originally Posted by oldfriend View Post
Check lags bolts !on that specific wheel
Thanx. Checked the wheel and they are...tight as a tick. Also checked alignment. will double check lugs. Yep...lugs good & tight too.
Old 04-20-2015, 12:58 PM   #9
wirebender
wirebender's Avatar
Just got back from my tuner...right away...as soon as he felt it...he knew what it was---- the catalytic converter. He says they just don't last at this power level. Going to have them gutted Thursday.
Old 04-20-2015, 06:09 PM   #10
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Awesome, glad you found it.
What power level?
Did the tuner give any reason why the cats would make a popping noise?
Curious. Thanks!
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
angryBits is offline   Reply With Quote
Old 04-20-2015, 07:56 PM   #11
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
Sure they can!
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 04-20-2015, 10:51 PM   #12
Mechzl1
Mechzl1's Avatar
Really the cats? Would have never thought that
Old 04-21-2015, 04:47 AM   #13
uihsongshi
Drives: bmw
uihsongshi is offline   Reply With Quote
Old 04-21-2015, 05:59 AM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
This is a normal issue.
The brakes seem to lock up after sitting for a while. It's most noticeable after you wash the car or do some "spirited" driving and then let the car sit.
The popping noise is the brake pads un-sticking themselves from the rotors.
Mods:
