Old 04-21-2015, 02:33 PM   #1
Santos
Santos
Santos's Avatar
Drives: 1SS Blk 6M ECS 1500
Question 2010 6M 40k miles Very bad vibration
So i am no mechanic by any means, but i know something is really going on with the car, and am tight on money so any help to get me looking in the right place would be very helpful. i have don't a search and can't find anything on an SS.
So i was driving the other day just fine, the next day i hit the gas and accelerate to about 36- 40 mph in third i believe. The car starts vibrating like the wheels in the rear are both going to come off.. i have not had any type of service other than an oil change as of late, and topping off my PS fluid. From 40-60 is when it is at its worst, and from 3rd to 5th gear id say. It vibrates the whole car, mirrors and all, i cannot hear any strange noise coming from the engine bay, and is perfect when sitting idle. From the other threads i have found anywhere close in topic, it may be a wheel bearing, differential, or engine mounts.. can anyone help, this car is to new and taken care of to well for it to be acting like this and is out of warranty now.
Santos is offline   Reply With Quote
Old 04-21-2015, 03:08 PM   #2
Shiftgreen
Shiftgreen's Avatar
Drives: 2014 2SS 1LE AGM
Jack the rear up and rotate the tires. If it's a wheel bearing you will hear it near the hub.
I had a differential go bad in a Tahoe and that was the nail in the coffin b/c it would cost more then what the truck was worth.
Shiftgreen is offline   Reply With Quote
Old 04-21-2015, 03:11 PM   #3
SS Blinder
SS Blinder's Avatar
Drives: 2011 SS (Sparrow Spearer???)
check your wheels for missing balancing weights or go get them balanced. have you recently bought new tires, if so, take them to where you got them, have them rebalance them. other than that, get under the car and check driveshaft bolts, driveshaft support bearing, bolts on axles, suspension, etc. good luck
Black magic woman, don't turn your back on me baby!
SS Blinder is offline   Reply With Quote
Old 04-21-2015, 04:04 PM   #4
Santos
Santos
Santos's Avatar
very hard to see, have only had one tire change on these rims, don't know how many weights usually go on a rim but there are some already on this rim, but also looks like there is some missing...
Old 04-21-2015, 07:02 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
If you put it in neutral and the vibration doesn't stop, then obviously it's not the engine.
Usually, speed dependent vibrations are wheel related. Start by looking for missing balance weights. I see you may have already spotted that as a probable cause.
Rock-It Man is offline   Reply With Quote
Old 04-22-2015, 04:06 PM   #6
Santos
Santos
Santos's Avatar
well balanced and aligned… still vibrating… $hit
Old 04-25-2015, 08:05 PM   #7
VINNY1980
VINNY1980's Avatar
Drives: 2010 camaro 2ss abm m6 , 2013 zl1
Send a message via AIM to VINNY1980
Look at driveshaft couplers . They like to wear out
VINNY1980 is offline   Reply With Quote
Old 04-26-2015, 08:56 AM   #8
laibehout
Drives: camaro
laibehout is offline   Reply With Quote
Old 04-27-2015, 07:33 PM   #9
BLACK67
Drives: 2010 Camaro 2SS/RS CGM
Send a message via MSN to BLACK67
Check the lower control arm, the sway bar tears out on the 2010's. Mine did.
SPi Performance Stage 3 package Comp Cam
PHADT FE4 ZL Stg.3
VMAX CNC Spiral Ported Throttle Body
Dynatech LT headers, Hi flow Cats
MBRP 3" 304 stainless X-pipe exhaust
Fastlane true CAI.
Barton shifter
BLACK67 is offline   Reply With Quote
Old 04-28-2015, 08:20 PM   #10
Santos
Santos
Santos's Avatar
Found the culprit for any of y'all who run into the same issue. Thx for all the help yall
Old 04-28-2015, 08:59 PM   #11
bkscott
bkscott's Avatar
Ok so what is that Bolt from?
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 04-29-2015, 05:52 AM   #12
Santos
Santos
Santos's Avatar
Driveshaft. This was cracked not all the way broke till they got it out and some were loose, all in the rear
Old 04-30-2015, 12:40 PM   #13
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
Interesting, I noticed some high speed vibes in my car around 80, it's not the tires but maybe I need to check my driveshaft bolts, I have some new ones anyway already.
Also I wish chevy used a one piece in these cars, another possibility is the center support bearing.
Glad to see you found your issue though.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
