INFECTED
Drives: 2011 1LT Synergy Green Join Date: May 2011
Chrome ring around the center of steering wheel
Has anyone been able to remove this part? The chrome ring around the steering wheel center. It's actually part of the air bag housing . I want to Paint it.
Any help & I would be greatfull . ..
INFECTED
59 # views and no answers ... Any one , is this just a trim ring which is pushed in ? Can it be lifted with a trim tool ? Or is there something holding it in from the back and there's no way to remove it and reinstall it .
Help ....
![]() Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
Couldn't you just tape off and cover dash etc to paint it? Considering I believe air bag is packed inside that I doubt I'd try prying or poking at it. I have no idea if that ring is removable. Perhapse ask someone selling a center section if they can look to see if it's fastened from behind. They do pop up fs from time to time. I believe air bag is packed in there though. Might have to ask someone who had the air bag pop on them to check it.
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
#4 | |
INFECTED
Xpect the unXpected
Drives: 2016 Camaro 2SS Join Date: Feb 2013
Good topic. Need some info on this too previous owner messed up the coating causing it to peal ugly. Thought about plastidipping it. There has to be some sort of disassembly to it. Since it in front of the airbag chose not to be messing with it.
UnXpected Performance-Xpect the UnXpected
#6 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
On my BMW the badge there faded but I just covered it with a sticker, everyone online warned about taking it off because of the airbag and it was less expensive to just cover it. If you decide to try to take it off make sure the battery is disconnected just to be safe
#7 | |
INFECTED
#8 |
Guest
Hope you find a solution, love your car so far
![]() I'm gonna guess you'll want it green???
#9 |
INFECTED
Thanks on finding solution , And thanks so much for the kind words on the car . I'm really not sure if I want it green or black .. I did get to black out the Camaro lettering in the center . I did that with a paint pen . Turned out great . But it was easy as its so small and you can't notice any in perfection's . But doing the ring ,I think it would not look good with the paint pen .
#10 |
![]() ![]() ![]() Drives: 2011 2SS Join Date: Jan 2013
I ended up using one of those paint pens. It didn't turn out great but it works temporarily. Have to see if I have a pic.
#11 |
SHKE BKE
Upgrade to the 2012+ steering wheel, IMO it looks a lot nicer
#12 | |
![]() Drives: 2015 Z/28 #525 Join Date: Apr 2012
#13 | |||
INFECTED
But thanks everyone for the ideas aND such. I will figure it some how . . When I put my mind to it. Might just get a circle of black vinyl and try that...lol
#14 |
INFECTED
Bump ttt. Has anyone done anything to the chrome ring? And what & how..
I can't believe someone hasn't done this yet.... Ideas , Help anything ?..
