04-23-2015, 12:56 PM | #1 |
Drives: 2011 2SS/RS L99 RJT Convertible Join Date: Sep 2014
"O" Ring Lubricant
Went to three different parts stores today and none of them carry "O" ring lubricant. I actually never heard of the stuff(neither did two of the shops).
Is there a substitute product I can use? From what I found on the web it looks like "O" ring lubricant is just a silicone based product. I'm installing a SC and in the instructions it calls for O-ring lube for the installation of the fuel rail and for the injectors.
Flowmaster Force II Axle back, Kooks LT's and Highflow Cats, Oracle Side Makers, BC Coilovers, E-Force Supercharger, Rotofab Intake, HexVents, ACS T4 Splitter/Rockers/Wind Deflectors, Aeroforce dual pod, Autometer boost/WB analog gauges, MRR M228 20x10 20x11 Nitto Invo 275/315's, CDC Sport Bar, Tuned by Slowhawk Performance.
04-23-2015, 02:09 PM | #2 |
This stuff works well for o-rings... I don't know if there are specific requirement for injector o-rings though...
http://www.homedepot.com/p/Super-Lub...2003/202932697
CAI intake | OBX LT Headers | Flowmaster AT Exhaust | Trifecta Tune | SS Rear Diff, Axles & Driveshaft Zex 100 Shot Nitrous | Konig Airstrike Wheels | Custom Engine Cover, Fuse Box & Underhood Bowtie Eibach Springs & SS Sway Bars | BMR Strut Brace | Drake Shifter | Vitesse Paddles | 13.26 @ 105.88 mph |
04-23-2015, 02:17 PM | #3 |
Drives: Red V8 Join Date: Jul 2014
I heard silicone lubricants aren't good for injector o rings
Live Hard, Drive Fast, Die Free. 'Merica
04-23-2015, 02:48 PM | #4 |
Found a link on a Corvette forum and there was a variety of alternatives, some from backshade mechanics to professionals. Here's a partial list:
1) Vaseline 2) Dish Detergent 3) Spit (gonna make those injectors my bitch) 4) KY The professional recommended the dish detergent as it evaporates over time and really the only thing your doing is trying to get the injectors in, not maintain some sort of O ring preservative.
04-23-2015, 02:55 PM | #5 | |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
04-23-2015, 04:35 PM | #6 |
Good to know...
04-23-2015, 05:07 PM | #7 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
All your trying to do us lubricate the o ring so it doesn't tear as you install it. You can use a little Mobile 1 oil on it to let it slide in. I've never used anything special to install an o ring.
USMC 1980-1990
My other toys are Harleys |
04-23-2015, 05:51 PM | #8 |
Drives: 2011 1LT RS camaro Join Date: Sep 2014
molykote
04-23-2015, 06:12 PM | #9 |
I would use a silicone grease. If you ever have to take it apart you don't want the o-ring tearing apart as you pull it apart later .
04-23-2015, 06:30 PM | #10 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
Preparation H
04-24-2015, 10:08 AM | #11 | |
04-24-2015, 10:23 AM | #12 |
Drives: CGM 2SS/RS, 1987 & 2014 Silverado Join Date: Oct 2010
Google Parker O-lube, it's barium based not silicone and very viscous.
04-24-2015, 10:51 AM | #13 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I've always used Vaseline even when making it my bitch.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-24-2015, 11:29 AM | #14 |
This is what I would do. Are they blue o-rings? If so, those are your typical fuel resistant fluorosilicone grade. A little bit of engine oil won't hurt anything.
