Old 04-23-2015, 02:19 PM   #1
jolson63
Drives: 2014 camaro ss
added K&N air intake
I added a K&N air intake on my 2014 Camaro SS 6.2 and it seem to run fine. But now I have a check engine code P1070 which is a MAP sensor type error. Anyone ever run into this?
jolson63 is offline   Reply With Quote
Old 04-23-2015, 02:32 PM   #2
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
Yea... Check all your connections. Mine was my MAF. Also make sure the MAF is in the right way
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 04-23-2015, 02:40 PM   #3
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Make sure you didnt damage your maf. Ive had mine for 2 years with zero issues.
rontammy0 is offline   Reply With Quote
Old 04-23-2015, 02:56 PM   #4
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
MAF could need to be spun 180 degrees
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 04-23-2015, 03:08 PM   #5
Splitter
Drives: '14 RRM 1LT/RS A6
this too
Splitter is offline   Reply With Quote
Old 04-23-2015, 04:11 PM   #6
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I think you mean "MAF". As others have said, you may have reconnected the MAF sensor upside-down (if that's possible). Also, the pre-oiled filter may be overloaded and the oil is interfering with the MAF signal. Lastly, if your greasy little fingers handled the MAF connections, it could just need a good cleaning.
One more thing - sometimes it takes a little driving (few hours/hundred miles) for the ECU and MAF to communicate properly. I don't think that CEL code will hurt anything... just keep driving it and it should go away after some cold restarts.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 04-23-2015, 04:12 PM   #7
solizaaron18
solizaaron18's Avatar
Drives: Camaro SS 2014
Once you get your little problem fixed… you will enjoy it. I actually have one myself. Cant really hear unless you punch it a bit but I believe that is all Intakes.
solizaaron18 is offline   Reply With Quote
Old 04-23-2015, 04:37 PM   #8
PalmerGA
PalmerGA's Avatar
CAI, Inc. intakes are very vocal, even at gradual acceleration... and especially when you punch it.
