Old 04-24-2015, 03:01 PM   #1
Mrbowtie26
Mrbowtie26's Avatar
Drives: 2015 CRT 1SS 1LE
Strange problem maybe related to drive by wire
So under a constant throttle position lets say 15% while accelerating slightly through 1st then 2nd gear the power is changing like I am pushing the pedal down more then lifting and repeating. Like its pushing me back in the seat a little then it stops then its pushing me back again. All with a constant throttle position. Is this the newer style drive by wire I guess it's called vs. the old throttle cable issue ? I would like to get any issues taken care of before I ruin my warranty by modding the car. It currently has 750 miles on it. The problem doesn't seem to be as noticeable once the car warms up.
Thanks
p.s. I do have the vitesse throttle controller but I have not installed it yet. I'm sure if I did the dealer would blame it on that.
Mrbowtie26 is offline   Reply With Quote
Old 04-25-2015, 07:38 PM   #2
horizon670
horizon670's Avatar
Drives: 2010 Chevy Camaro 2LT / RS / Auto
Yes, like you said, don't install the Vitesse Controller until you get your issue resolved. Sounds like a faulty Throttle Position sensor or the accelerator pedal Sensor going bad.
horizon670 is offline   Reply With Quote
Old 04-25-2015, 08:56 PM   #3
Mrbowtie26
Mrbowtie26's Avatar
Ok thanks
