![]() Drives: 2015 Blue Velvet 2ssRs1Le Join Date: Mar 2015
Oil leak?
So I've had my car for 2 weeks, and I think there's an oil leak. 500 hundred miles, possible? I haven't had a chance to look underneath yet. Thoughts?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Red Hot LS3 Join Date: Oct 2014
What makes you think there is an oil leak? Dipstick low?
#4 | |
My 2012 L99 2SS was bone dry underneath for the first 18 months or so, but at 10k miles, I saw a oil spot every three to five days of sitting... I whined about it a bit, but next time I went to change the oil, I saw the oil filter had drips on it. After I changed the oil, I made sure the filter was tight. No drips since.
Get under it and find out where its coming from, might be an easy fix!!! |
#6 |
![]() ![]() ![]() Drives: 2020 rally green rs Join Date: Oct 2013
put a white paper under the car then you will really know!
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
When I bought my Silverado in o2, the oil cooler was leaking. When I took my Camaro apart at 22k, it was leaking too. Both those times I just have the 10mm bolt a little tighten (careful your putting a steel bolt into aluminum).
Recently had to replace the cooler gasket on the Silverado at 155k.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#8 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
I just had this problem when i first took my car out of the garage after winter. I noticed a small puddle of oil...like i could get under the car to see. So i took my phone..hit record and reached under the car as far as i could. I recorded the area i thought the oil was coming . Once i watch the vid i could see oil was dripping down the side of the filter. When i had my oil changed they confirmed it was leaking...now its bone dry.
#9 |
I put white paper underneath and stayed clean. Talked with my brother and realized that he parked his old 69' Coronet on these boards. So false alarm. Thanks for the ideas.
#10 |
#11 |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
I'm sorry to hear about your potential oil leak. I understand how displeasing this would be and realize you're seeking opinions about it. However, if you'd like to consider getting an official GM diagnosis, please message me privately as I can reach out to the dealer's Customer Experience Managers (CEM) for additional assistance. If you'd like to contact us privately, we'd be happy to discuss this with you further. Kindly, William R. Chevrolet Customer Care |
