Old 04-25-2015, 11:58 AM   #1
bryaannnn6
bryaannnn6's Avatar
Is this normal on your camaro?
Hey guys I just got my first oil change about two days ago, so this morning I thought I'd check my oil to make sure everything was good(haven't drove it since). Anyways I saw this and I was like what the hell? Its like the paint melted maybe from the brake booster? Is this normal on your guys' V8/V6? If not, what can I do, dealer wise. I'd appreciate some insight!
bryaannnn6 is offline   Reply With Quote
Old 04-25-2015, 12:12 PM   #2
spyderbuddy
Yea, Had That same Problem. The Brake Fluid Reservoir/Cap leaks.
There is a TSB for that problem. Miine was out of the 36/3 year Warrenty so I had to pay for the Fix. they have to Replace the Reservoir and Cap.
Old 04-25-2015, 12:56 PM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
No need to replace the reservoir or cap.
Just go buy this:
Less than $10 and it will fix your problem.
Mods:
Old 04-25-2015, 01:18 PM   #4
bryaannnn6
bryaannnn6's Avatar
I'm thinking that since I still have warranty might as well have them fix it and document. I'm thinking of trading up to a 1LE from my 1SS. They better not taking off money off that lol
Old 04-25-2015, 04:27 PM   #5
Dale_K
Drives: 2014 1LS
It looks like the brake fluid has taken off the paint on the fender/firewall structure below the reservoir. Yeah, I'd take it to the dealer.
Plus the leak could eventually make the brakes fail.
Dale_K is offline   Reply With Quote
Old 04-25-2015, 10:53 PM   #6
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
How much brake fluid is in the reservoir? The reservoir looks empty.....unless the fluid is brand new.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 04-25-2015, 11:28 PM   #7
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
Kaboom has the answer if they wont fix it...it's a common problem, the whole system is not much better than the cap itself.
backeddy is offline   Reply With Quote
Old 04-26-2015, 03:08 AM   #8
bryaannnn6
bryaannnn6's Avatar
It's filled up all the way, I'm thinking they did so when I took it in for my first oil change.
Old 04-26-2015, 03:09 AM   #9
bryaannnn6
bryaannnn6's Avatar
Thanks guys! I doubt they won't fix it. I'm still under warranty. Just pissed me off that its a '14. They should have fixed it by now lol
Old 04-26-2015, 10:03 AM   #10
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
They did fix it on 14's from what i understand they fixed it late model 13's much like on the late model 2011's you got the strut tower holes pre-drilled for the brace. Someone at your dealership/oil changes locale overfilled or didn't tighten the cap enough or torqued it more then needed and ruined the seal. Had mine done after it ruined some underhood accessories it is just the cap and seal that needs to be replaced.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 05-07-2015, 03:20 PM   #11
Speedfreak391
One man Army
Speedfreak391's Avatar
Drives: 1987 Iroc Players car
So what are they doing about the paint that has blistered off? In the pic above that means the entire engine compartment needs to be repainted. Who pays for that? It wouldn't be me, and I am going to go check mine right now.
1987 Iroc-Z with a turbo 5.3, T-56, Moser 9", and lots of other goodies.
http://www.mifbody.com/vbulletin/sho...87-IROC/page24
2010 Camaro 2SS/RS with a K&N cold air Stainless Power headers, Magnaflow cat-back, staggered TSW Nurburgring's just a great daily driver.
Speedfreak391 is offline   Reply With Quote
Old 05-10-2015, 08:04 PM   #12
Sam94
Sam94's Avatar
Drives: 2015 Camaro 1SS RS
I checked mine today and its leaking as well. Seems overfilled too.
Has anyone confirmed that the Dorman part fits a '15 ? When I checked it online it said Not Compatible.
2015 Camaro 1SS/RS Blue Velvet Metallic, L99, Airaid Intake Tube, Akebono Ceramic Brake Pads, Borla S-Type Axle Back, GM Strut Tower Brace, Range Device
Sam94 is offline   Reply With Quote
Old 05-10-2015, 10:04 PM   #13
camaro500
camaro500's Avatar
Drives: 2017 Jaguar F Type R Tuned 498awhp
yes it fits and ouch to the OP! Get to checking your reservoir everybody because THE CAPS LEAK! It is a garbage design!
JRE cammed w.full bolt ons 444rwhp/422rwtq SOLD
''Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.'' - F. Bueller
camaro500 is offline   Reply With Quote
Old 05-10-2015, 10:07 PM   #14
Camarodriver2
Camarodriver2's Avatar
Drives: FOR SALE! Bumblebee 1 of 1
What years were the caps leaking? I have a 2011.
My 1 of 1 Bumblebee: Paint=House of Kolor Sunrise. Shaved door handles and concept handles added. Shark fin removed, concept mirrors, Showstoppers concept LED side marker lights. Wiper blades removed, muffler delete, and Range AFM disable. BMR springs lowered 1" rear and 1.4" front and added Eibach wheel spacers - 20mm rear and 25mm front.
Camarodriver2 is offline   Reply With Quote
