Old 04-26-2015, 02:44 PM   #1
pbclax1
Drives: Car
BC Coilovers
I am lowered on BR type coilovers about 1.2" and dont seem to have much space between the top of the tire and the wheel well to go much lower. Nor does it seem on the coilover body that I have much space left for lowering (about 3/4" between the rings in the front)? The threads I see with the car lowered 1.5" all around, I don't see how that is feasible with what I am looking at regarding rubbing. Running stock 245/45r20 and 275/40r20 rear tires.
pbclax1 is offline   Reply With Quote
Old 04-27-2015, 04:03 PM   #2
pbclax1
Drives: Car
Anyone running these have comments/pictures on their ride height, wheel size, and rubbing?
Old 04-27-2015, 08:20 PM   #3
mikey1107
mikey1107's Avatar
Drives: 2017 SS
I have pedders which are similar lowered about 1.5" and could easily go lower.
Sent from my subconscious
2017 SW SS
mikey1107 is offline   Reply With Quote
Old 04-27-2015, 10:18 PM   #4
pbclax1
Drives: Car
What's your height from the bottom of the rim to the fender on the front and back?
Old 04-27-2015, 10:23 PM   #5
mikey1107
mikey1107's Avatar
Drives: 2017 SS
25.5
2017 SW SS
Old 04-28-2015, 10:10 PM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
I ran BC coilovers with about a 1.5" drop and 275 on 20x9 all around. No rubbing at all. Just watch how close you pull up to the curbs.
Build Journal
Old 04-29-2015, 05:44 PM   #7
pbclax1
Drives: Car
Awesome. How much space did you have left between the collars on the coilover for adjustment?
Old 04-29-2015, 07:25 PM   #8
CamaroSS sleeper
Drives: Sleeper_NOT
I have BCs about a 2" drop.
1. wheel offset can determine how much you can lower the car.
2. Camber Alignment (negative camber will help you tuck the tire, dont go crazy on the negative camber do.. -0.8 max or youll have tire wear problems.)
3. width if tire and wheel.
Im not sure on stock wheels..
but My setup is Zl1 replicas per GM specs
11" wide wheel rear with 295/35/20 michelins -----10" wide wheel front with 275/40/20
clearance is tight as a virgin in my car, but no rubbing
CamaroSS sleeper is offline   Reply With Quote
Old 04-29-2015, 10:10 PM   #9
pbclax1
Drives: Car
Nice ride!! Any more pics of it? Are the BC's maxed out with that drop or do you still have space between the collars to go lower if you wanted?
Old 04-29-2015, 11:59 PM   #10
CamaroSS sleeper
Drives: Sleeper_NOT
Thanks!!
I still had about 1/2 drop between the perches.
But i actually had to lift it about 1/4 all around because it was simply too low to be a DD.
Anyways...
Here is two other pics while it was still nice and low.
Old 04-30-2015, 07:33 AM   #11
pbclax1
Drives: Car
Awesome! Really nice setup! Thanks for the info.
Old 04-30-2015, 10:18 AM   #12
Assassinx1
Drives: Corvettec5
What spring rate does OP have and can you take a pic of your coils. And how many miles did you put on them sometimes thy need to settle.
Assassinx1 is offline   Reply With Quote
Old 04-30-2015, 08:22 PM   #13
pbclax1
Drives: Car
The spring rates are the factory bc br type coiliver rates. I can get pics soon and it's been around 200 miles. They do seem to have settled some for sure. I have about 3/4" between my collars up front left for adjustment and about 1-3/16" in the rear.
Old 04-30-2015, 09:54 PM   #14
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Coil rates are about 460 front and 560 rear
VR Baron is offline   Reply With Quote
