Old 04-26-2015, 07:35 PM   #1
mark1
Drives: 2015 1LE 2SS RS Summit White
P015d and P015 d codes
Hello i have a 2015 1LE SS. My engine mods are few. i have a CAI intake, catch can. I got these coded today while cruising down highway. car has 3000 miles. Any ideas?
mark1 is offline   Reply With Quote
Old 04-27-2015, 05:34 PM   #2
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
Well its an O2 code. Check the obvious like Air intake clamps, loose vac hoses.
If nothing obvious is found then it could just be a bad O2.
thiggin2 is offline   Reply With Quote
Old 10-09-2015, 11:48 PM   #3
LastGen5
Manual Guy - Until Now...
LastGen5's Avatar
Drives: 2018 ZL1 A10
I started getting these codes when I installed the air scoop for my CAI. I installed a new MAF today - hopefully that solves the issue. Did you end up getting to the bottom of your issue?
LastGen5 is offline   Reply With Quote
Old 11-04-2015, 06:35 PM   #4
LastGen5
LastGen5's Avatar
Actually, I'm pretty sure my intermittent codes were caused by my Vitesse throttle controller. I've been experimenting: SP5 and I get the occasional code (P015B/D), SP4 seems to eliminate it them.
