what is the gear ratio on a stock v6 camaro?
Im thinking about upgrading to maybe some 3.73 gears or 4.10's what go you guys think??
Camaro Fanatic
I thing the stock ratio was 3.08 gears. I had the Y87 package which were 3.42's. They were great, also had a custom shift kit and vette servos installed. I think anything over 3.42's would be too much for the 3.8L. check out firebird******* its packed with tons of info and is dedicated to the V6 Fbodys
heres something I found on that site: 2.73 - These do not come as factory equipment on any V6 F-Bodies, though they are offered on some V8 models. Gears this low are designed for two things: sustained high speeds (very, very high speeds, like Autobahn-style) and for long-distance highway gas mileage. An F-Body equipped with 2.73s will have a very low rpm at highway speeds, and coupled with a 6-speed transmission they are excellent for long-distance cruising. Low-end acceleration, however, is terrible. The engine has to struggle to get the wheels to spin, so do not plan on getting 2.73s if you enjoy actually moving when you hit the gas at a stoplight. V8 owners can get away with running 2.73s because they have obscene amounts of low-end torque, but there is no real reason any V6 owner would want these. Contrary to popular belief, a V6 equipped with 2.73s would actually get worse mileage than stock if doing any sort of city driving, because the engine has to struggle so hard to get the car up and running. That alone cancels out the low-cruising rpm advantage. 3.08 - These come as factory equipment on base model automatic 3.8s. These gears are great for fuel economy but offer very sluggish acceleration. If you are even remotely interested in performance stay away from 3.08. V6 owners have been known to drop from 15.8 to 15.2 in the quarter mile just by switching from 3.08 to 3.42. 3.23 - These come as factory equipment on all 3.4s and on manual 3.8s with or without the Y87 performance package. Since the Borg-Warner T-5 manual transmission has five gears compared to the 4L60-E automatics four, manual owners can get away with using this lower ratio. For the majority of manuals these gears tend to work best: they combine a good mix of acceleration and very strong top end. They are, however, still a bit low for most automatics. 3.42 - These come as factory equipment on automatic 3.8s equipped with the Y87 performance package. 3.42s are probably the most popular gear ratio for performance-minded V6 owners because they offer great acceleration without killing too much top end. If you have an automatic its pretty safe to say that 3.42s are your best bet. Some manual owners have switched to 3.42s and have had good results with them as well. 3.73 - These do not come as factory equipment on any F-Body. 3.73s offer arguable gains. Low-end acceleration is excellent and you can be assured of quicker 60 foot times with 3.73 gears equipped. However, the 3.8 V6 in naturally aspirated trim tends to fall flat on its face in higher gears--fourth for manuals and third for automatics. 3.73s will put you in those high gears quickly, so then when you actually get to the top end your acceleration will be decreased at best, butchered at worst. Additionally, with 3.73s equipped your engine will be rev quite high when driving at highway speeds, typically at 2500-2800 rpm. For prolonged periods of time this can cause excessive engine wear and terrible gas mileage. 4.10 - This is truly all-out when used on a V6. 4.10s should only be used by serious drag racers who dont care how much gas their car guzzles on the streets. On a naturally aspirated 3.8 they will kill the top end, so dont even think about 4.10s unless you are running forced induction or nitrous oxide to make the additional power they will need. Last edited by TFord; 09-03-2009 at 03:56 AM. Reason: more info |
wow thanks you answered my question and more!
Banned
Drives: 2010 LS Join Date: Feb 2021
He was 100% incorrect, the V6 has 3.27 gears.
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
You do realize this is a 12 year old thread pertaining to the GEN 4 F-body right?
| Winner, winner - Jalopnik compares the Big 3 | Number 3 | 5th Gen Camaro SS LS LT General Discussions | 31 | 04-17-2011 03:24 PM |
| V6 Camaro Owners! 2010 V6 Zex Nitrous System now available! | Kris@BMCPerformance | Forced Induction | 3 | 01-23-2010 02:41 PM |
| Pedders takes delivery of their SS Camaro | Info@PeddersUSA.com | Wheels and Tires Talk Sponsored by The Tire Rack | 41 | 07-31-2009 10:44 AM |
| STOCK V6 2010 CAMARO | et7333 | Dragstrip and Launch Techniques Discussion | 2 | 07-14-2009 09:37 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
