Old 04-27-2015, 09:44 PM   #1
fleebag
fleebag's Avatar
Drives: Moneypit
Stabilitrac and ABS, TC's on
While trying to do a log starting in 2nd gear through top of 3rd all the lights came on and Won't go out. Service Stabilitrac, ABS,and TC's
However, there is no dtc's but if i click clear anyway they go out but come back up the road a bit.
The on ramp was quite bumpy and tires were spinning too. I messed up and forgot to turn off all the nannies beforehand.
I have tried most all I found using search but no luck. I did read somewhere about a tech2 gm tool? Will this show exactly what the issue is?
I hooked up my HP tuner but it did not see any codes either. Can it tell if a speed sensor is bad?
I did have an extremely low clutch reservoir(separate). It was leaking and didn't see it until now. Added fluid and drove and it drives fine.
Here is what I have tried;
1 hr battery disconnect
24 hr battery disconnect
Run car turn off, remove key, open close door etc
pulled abs fuse,ecm fuse
removed and replaced plugs and inspected wires
retuned with same tune
inspected rear wheel speed sensors, just feeling lines no cuts or chips
should I remove and inspect?
Throttlebody is less than year old Bo White just unplugged and repluged
Thanks in advance
fleebag is offline   Reply With Quote
