Old 04-28-2015, 11:35 AM   #1
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
Torque Specifications For Front & Rear Suspensions Please
Does anyone have a Torque Specification Chart for the SS FRONT & REAR SUSPENSION handy. I am adding coil overs to the car & want to MAKE SURE that ALL of the SUSPENSION BOLTS are tightened to the CORRECT Torque.
Thanks In Advance For All Your Help!
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 04-28-2015, 09:21 PM   #2
Mike_G
Drives: 2010 2SS/RS
nice upgrade!
http://www.camaro5.com/forums/showth...pension+torque
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 04-29-2015, 12:21 PM   #3
Orange 2010 Camaro
Originally Posted by Mike_G View Post
THANKS-A- MILLION guys for the Torque Specification Chart!
Having ALL BOLTS torqued CORRECTLY is what keeps us MUCH SAFER while driving.
All The Best,
Orange 2010 Camaro
Old 04-29-2015, 03:47 PM   #4
JusticePete
Drives: Camaro Justice
Old 06-12-2015, 01:45 AM   #5
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
Thanks Pete!
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
