Old 05-03-2015, 12:08 AM   #1
thebigbankhank
Drives: 03Avalanche,2012cbr1000rr,2010iomSS
Car has an oil leak... extended warranty won't cover
Took my car in 3 days before the factory warranty expired for a leak. After a week of going back and forth between the dealer and warranty company, it wasn't covered. Dealer says the power train warranty is blocked on the car due to modifications from the previous owner. Extended warranty company says that since I took the car in before the factory warranty WOULD have expired, their extended warranty won't cover the repairs and if I would have taken it in a week later, it would have been good. 2010 m6 Ss with only 32k miles. Dealer suggested the oil pan gasket be replaced... I've looked myself and it seems to be leaking somewhere in the front and on the side by the starter... I'm open to ideas on how to get this squared away... All I did was buy my dream car for my birthday...
thebigbankhank is offline   Reply With Quote
Old 05-03-2015, 02:35 AM   #2
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Did they disclose at time of sale that the factory warranty was void? If not, insist that they honor it. Also get a list of what mods supposedly voided it. Odds are none of them have anything to do with were the oil is leaking from.
Sounds like you are being given the run around. You could always come back later and get it looked at from where it's really leaking, doesn't sound like the oil pan gasket if oil is higher up.
BigBlock69RS is offline   Reply With Quote
Old 05-03-2015, 07:38 AM   #3
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Do some searching for oil leaks on 2010. I know the oil cooler was a popular problem. Here's a link I found doing a quick google search. I know someone this happened too.
http://www.camaro5.com/forums/showthread.php?t=101763
bannonm is offline   Reply With Quote
Old 05-03-2015, 09:04 AM   #4
thebigbankhank
I bought the extended warranty from the bank. Per the owner I know why it was voided but per the bank, dealer and extended warranty co, I don't... I'll do some more looking to see if I can see where the leaks coming from. I might take it to another dealer and just say fix the leak based off my gaskets and seal warranty on my extended warranty company. It looked like it was around the starter some and somewhere on the front.
Old 05-03-2015, 09:29 AM   #5
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
Mine was in the shop 4 times for oil leaks, starting with 3000 miles on her. First the rear main was replaced. they hinted that when I put my Hurst shifter in I "may have disturbed the seal" Considering the constraint when I ordered it in 2008 for the shifter caused my VIN to be over 9000 and should have been in the first few hundred I told them dont go there! then 3 other times drip drip drip... first was o rings to the oil cooler then both other times was blamed on "silicon seal block to drain pan" now it is 6 years old and 8000 miles on her, dry under it finally!
GOODLUCK!
superstockcam is offline   Reply With Quote
Old 05-03-2015, 09:53 AM   #6
CRF8
Scenic City Camaro
CRF8's Avatar
Drives: 2022 Camaro ZL-1 /1974 Firebird 400
You should review all the papers you signed at purchase. It was a used car, but with remainder of factory warranty? OR did it say "as is" no warranty (from GM). I never buy extended warranty's so I don't know about their excuse.
CRF8 is offline   Reply With Quote
Old 05-03-2015, 10:18 AM   #7
speedygonzales
speedygonzales's Avatar
Drives: 99 z71, 2012 2SS
What mods were done before?
There are alternatives to fighting them up front. Get the repair done and then issue a Warrant In Debt with the court system. They will likely pay the bill at that point instead of paying a lawyer to show up in court.
Fix your garage pics so we can see them
speedygonzales is offline   Reply With Quote
Old 05-03-2015, 10:36 AM   #8
thebigbankhank
If i remember right the original owner put 3" exhaust and long tubes with cutouts on it with an intake and tune.
Old 05-03-2015, 11:46 AM   #9
CRF8
Scenic City Camaro
CRF8's Avatar
Well the exhaust certainly has no connection to an oil leak. I wonder if they would contend the tune may have caused it. Ask them what specific mod could relate to an oil leak,
Old 05-04-2015, 03:30 PM   #10
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
How much does this kind of fix cost? DIY of course
Dmpsix is offline   Reply With Quote
Old 05-04-2015, 04:36 PM   #11
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
The cost of an oil pan gasket, which is $37. Sometimes the pan itself has to be replaced though. When I went through this, my pan had to be replaced as well. At that point, add a few hundred more to the cost of a DIY repair.
The devil is in the details though. You have to drop the entire front rack to get to the oil pan. This repair rings up north of $1,500 at a dealership because of the man hours involved in the repair. Likely it will be in the 2 grand price range with a new pan and gasket.
TheHorse13 is offline   Reply With Quote
Old 05-05-2015, 11:46 AM   #12
thebigbankhank
dealership quoted 1000, few friends with shop quoted 500 and diy with some buddies, sometime and some food and beer just the price for parts, food and beer....
Old 05-05-2015, 12:48 PM   #13
TheHorse13
TheHorse13's Avatar
Ask the dealership if that price includes a new pan. 500 sounds right if you DIY and it includes a pan and gasket.
Old 05-05-2015, 11:08 PM   #14
thebigbankhank
Ill ask.
