Old 05-03-2015, 04:28 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
HP Tuners group lessons
Anyone know of any group lessons around the Maryland / DC/ Va area?
etmx183 is offline   Reply With Quote
Old 05-15-2015, 03:40 AM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Try Greg Banish's facebook page and see what his schedule is, if that does not work then you may want to email him and see about when he will be over in that neck of the woods.
http://calibratedsuccess.com/faqs/
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-15-2015, 10:15 PM   #3
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Unfortunately, Greg called out a couple "cartooners" and was thrown off the board. He was great at explaining functions of sensors
He works for Ford now and cant teach any longer
If you have a group of ten or more, I may entertain teaching calibrations if the shop has classroom and a dyno.
Tampa Tuning is offline   Reply With Quote
Old 05-16-2015, 11:51 AM   #4
1KillerSS
1KillerSS's Avatar
Never knew that, his website shows that he still does classes.
Build thread
hp tuners
