Old 05-04-2015, 07:43 AM   #1
dragonkeyper
Drives: Black 2010 Camaro LT
Should there be a gab between Upper Strut Retainier and body after lowering
After installing lowering springs on the front of my Camaro I noticed a 1/4 between upper strut retainner and the strut housing. Is this normal? The upper nut is tightened to the point the Upper Strut Retainer is making contact with the Spring Perch Retaining nut. See attached images any guidance would be much appreciated.
Thanks
Never mind Found answer to question in this post. Thanks
http://www.camaro5.com/forums/showthread.php?t=396671
dragonkeyper is offline   Reply With Quote
Old 05-04-2015, 09:14 AM   #2
Carmikaze
HTCC Membership Director
Carmikaze's Avatar
Drives: 2013 RS Camaro
Get this and put it there. Cleans up the look.
Carmikaze is offline   Reply With Quote
Old 05-04-2015, 09:33 AM   #3
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
The gap is always there to some degree.
Old 05-04-2015, 04:53 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
The Gap is supposed to be there as the assembly pivots. If the gap was not there, the suspension would bind up!
Old 05-05-2015, 09:50 AM   #5
JusticePete
Drives: Camaro Justice
This is why the gap it there. It allows the strut to articulate.
Restricting the movement with a toilet seal is not recommended.
This is what the articulation looks like after installing JPSS Camber Plates.
