Old 05-04-2015, 12:20 PM   #1
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
SS stock ride height
Anybody have the rear wheel stock ride height of a SS with eom 20" rims and eom 275/40 Pirellies ?
camguynj is offline   Reply With Quote
Old 05-04-2015, 12:46 PM   #2
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
OEM?
Measured where?
JimE is offline   Reply With Quote
Old 05-04-2015, 04:22 PM   #3
camguynj
camguynj's Avatar
Originally Posted by JimE View Post
OEM?
Measured where?
Measured ground to middle of wheel well. thanks
Old 05-04-2015, 06:23 PM   #4
Cart7381
Drives: 2013 Camaro SS M6
I have 29 and 7/8"
Cart7381 is offline   Reply With Quote
Old 05-04-2015, 07:59 PM   #5
camguynj
camguynj's Avatar
Originally Posted by Cart7381 View Post
I have 29 and 7/8"
Both wheels?
Old 05-04-2015, 08:51 PM   #6
Cart7381
Both rear wheels
Old 05-04-2015, 08:52 PM   #7
Cart7381
Crap may have read this wrong I measured from ground to middle wheel well fender
Old 05-04-2015, 09:01 PM   #8
camguynj
camguynj's Avatar
Like this
Old 05-05-2015, 08:02 AM   #9
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
If you want a consistent measurement, take it from the bottom of the wheel to the wheel well. Tire pressure and weight can throw the measurement off if you measure from the ground.
bannonm is offline   Reply With Quote
Old 05-05-2015, 08:34 AM   #10
JusticePete
Drives: Camaro Justice
Front 690mm +/- 5mm
Rear 700mm +/- 5mm
Measured from the bottom of the wheel rim lip, up through the wheel center to the painted edge of the fender on 20" wheels. We use this methodology because it removes differences in tire size brand to brand and inflation. It also uses a hard point (the bottom of the wheel rim lip) to eliminate human error.
Old 05-05-2015, 09:19 AM   #11
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Before I knew to measure from the whell lip and when my car had 30 miles on it the rear was at 30.125". Idid measure later the difference of the tire height which was 3" so 27.125", plus or minus a fraction of an inch from wheel lip to fender
VR Baron is offline   Reply With Quote
Old 05-05-2015, 01:20 PM   #12
camguynj
camguynj's Avatar
Cart7381
I have 29 and 7/8"
bannonm
JusticePete
Front 690mm +/- 5mm
Rear 700mm +/- 5mm
VR Baron
Before I knew to measure from the wheel lip and when my car had 30 miles on it the rear was at 30.125". Idid measure later the difference of the tire height which was 3" so 27.125", plus or minus a fraction of an inch from wheel lip to fender
All good info. Thanks much! I'm planning on installing QA1 rear single adjustable coilovers (which use the factory spring) just to get a softer ride -no lowering- so I want to get a baseline height to match to after the install.
Old 05-05-2015, 06:41 PM   #13
Cart7381
Yeah 29 7/8 measured just like the video I think I was at 33 or 34 psi
Old 05-07-2015, 10:11 PM   #14
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Before i lowered mine my good buddy called my camaro a "4 wheeler" our cars sit way to high. Lowering out vehicles makes a world of difference.
Nighthawk89 is offline   Reply With Quote
