Old 05-08-2015, 08:05 AM   #1
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
Drives: Zoe the ZL1, 2012 Frontier
Programming fob causes "service anti theft system" on DIC
Hi everyone.
I have a 2013 ZL1. I recently acquired the non switch blade key and a new fob from a dealer who I do not live near.
The key works fine but I tried to program the fob (came unprogrammed) and when I put the cut shank from an existing switch blade key in (just the metal part) the new fob and did the whole "turn master key to on. Wait ten seconds. Insert key fob to be programmed in, turn back on" I got the service message on the DIC and the little warning light with the car/lock symbol on the gauge too.
Now when I used the new non switch blade Key and my original key that message disappeared and when I put the shank back in its original fob it also disappeared but I couldn't get the car to program the fob.
Did I do something out of order or did GM change the programming metrics? I haven't seen this mentioned in searching for programming the fob.
Guess it's off to a local dealer to try and get the fob programmed.
FOR SALE: 2013 ZL1 Message me if interested
G-Oil Guy is offline   Reply With Quote
Old 05-08-2015, 05:53 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
As far as I know, you should have retained the original fob.
Rock-It Man is offline   Reply With Quote
Old 05-08-2015, 06:27 PM   #3
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
You need to insert the new fob/key BEFORE 10 seconds.
thiggin2 is offline   Reply With Quote
Old 05-10-2015, 03:01 AM   #4
G-Oil Guy
Where am I?
G-Oil Guy's Avatar
You misunderstand, I bought these because I do not want to give up the original switchblades. I want to keep those 2 and have 1 "Recall Key" and new fob. Basically 3 sets of keys.
I did, it gave me that error.
I used the original key, turned the car on, let it run for a minimum of ten seconds, turned off, inserted new fob (with the key shank from one of the spare sets) within ten second, got the error message.
