Old 05-08-2015, 11:13 AM   #1
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
Anyone running BMR 1.4 springs
Is anyone running BMR 1.4 drop springs up front with 285/35 tires? Any rubbing issues with the setup or other concerns?
I currently have Pfadt / Apex 1.2 drop springs but still have about an 1 1/4 of fender gap up front.
zfuzz is offline   Reply With Quote
Old 05-09-2015, 05:00 PM   #2
Mike-ZL1
Mike-ZL1's Avatar
Drives: 2014 ZL1 Camaro
BMR 1.4 lowering springs
I installed them last month have put about 400 miles on car sense install and very pleased with ride not much stiffer than factory in all settings no rubbing issues I am running 285/35/20 and 315/30/20 and I have hit some decent size bumps and no problem F@ in New England roads :( good luck
Mike-ZL1 is offline   Reply With Quote
Old 05-09-2015, 08:40 PM   #3
2K13_ZL1_BLove
Drives: 2013 Summit White ZL1
Absolutely love them. Ride is similar to stock.
2K13_ZL1_BLove is offline   Reply With Quote
Old 05-09-2015, 08:44 PM   #4
2K13_ZL1_BLove
Another pic. Rear tire.
Old 05-09-2015, 08:47 PM   #5
2K13_ZL1_BLove
Front tire.
Old 05-09-2015, 08:48 PM   #6
2K13_ZL1_BLove
Had them for over 5K miles, love them. I switched to 315 rears and no issues. Read tire is also a tad taller and car has settled down further. So there is basically no wheel gap at all anymore.
Old 05-10-2015, 11:25 AM   #7
zfuzz
zfuzz's Avatar
Awesome, thanks guys for the input and the pics. They have been ordered
Old 05-10-2015, 08:31 PM   #8
Mike-ZL1
Mike-ZL1's Avatar
Congrats you will love them it is amazing how much it changes the look of the car much more aggressive look but not to low did the install my self and was very easy hardest part was the wires on the rear shocks so that tells you how easy install is good luck
Old 05-10-2015, 09:08 PM   #9
Mike-ZL1
Mike-ZL1's Avatar
Pix
Old 05-12-2015, 03:11 PM   #10
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
Originally Posted by Mike-ZL1 View Post
Pix
Mike how is the ground clearence up front with the drop and splitter ?
BigBlock427 is offline   Reply With Quote
Old 05-12-2015, 08:32 PM   #11
Mike-ZL1
Mike-ZL1's Avatar
Big block 427 ground clearance is 4 7/8 inches high from tip of splitter my car will probably settle a little more like an eighth or two so should end up with 4 3/4 of inch after some more miles on springs and alignment just have to be more couscous of speed bumps and inclines angles are your friend good luck
