05-08-2015, 04:12 PM | #1 |
Pennzoil Platinum or Royal Purple?!
I know I know another idiot wanting an oil opinion. I want to know which oil you guys think is the better to go with, not worried about price, I want what's best for my car. Thanks!!
2011 2SS/RS
*Sold* 2014 2LS V6 |
05-08-2015, 04:39 PM | #2 |
There is almost no difference between those oils. Both are good choices and both will work equally well with any engine. I put Pennzoil Platinum in my car on my last oil change.
05-08-2015, 04:46 PM | #3 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
I vote Neither.. Amsoil would be my choice if i didnt get mobile 1 extended from walmart at a decent price. Ill be changing to amsoil once my cam goes in.
05-08-2015, 04:47 PM | #4 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
I run the Penzoil Platinum in my wife's Escape and Amsoil Signature Series in my car.
05-08-2015, 05:27 PM | #5 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
I use Royal Purple, was using Mobile 1 before and with my LLT I was getting a lot of blow-by. With RP it isn't nearly as bad. Also very easy to see what the fresh oil level is since you can see the purple dye.
05-08-2015, 05:31 PM | #6 |
I run Joe Gibbs LS30, but that's because of my cam. If I were stock then I would recommend Amsoil Signature Series.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
05-08-2015, 05:58 PM | #7 |
Drives: camaro 2LS LFX A6 Join Date: Jun 2013
PP since the day I bought it (got it brand new)
Sent from Galaxy Note 4
Niche 20x10.5, BMR 1.25 springs, GFX splitter,1LE Diffuser w/ 3.5 quad tips
05-08-2015, 06:27 PM | #8 |
Drives: Just a fan for now Join Date: Apr 2014
Not as easy to see on the dip stick but Mobil 1 0W40... for all of my cars.
05-08-2015, 06:32 PM | #9 |
Drives: camaro 2ss Join Date: Jul 2014
+ 1 on the Amsoil Signature Series.
05-08-2015, 06:52 PM | #10 |
I like Mobil 1 or Amsoil.....
05-08-2015, 08:00 PM | #11 |
Drives: 2013 Camaro Dusk 2SS/6 Join Date: Sep 2013
mobil 1. it's proven, cheap. if the space shuttle used it, you'll be fine.
the only common oil to test better is pennzoil ultra (which I think is now called ultra platinum, not the same as platinum) but in reality, any good synthetic will work just fine. |
05-08-2015, 09:04 PM | #12 |
Drives: bicycle Join Date: Jun 2014
Amsoil...
05-08-2015, 10:03 PM | #13 |
Drives: 2015 Challenger SRT Join Date: May 2011
I've tried both and both have been just fine!
05-09-2015, 06:19 PM | #14 |
A stock engine in what is basically a daily driver? It's pointless to spend the money for Amsoil, Royal Purple, and the like. I use Pennzoil synthetic blend (as the manual recommends) every 5,000 miles.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
