Old 05-09-2015, 11:26 AM   #1
hotlap
hotlap's Avatar
Drives: 20 1LE 2SS M6 Rally Green
How to pull wire pin from fuse block
I need to solder a splice on to pin 15 (charge air coolant pump). I see the gray retaining clip and pulled it out. Is there a trick to getting the pin out. I've tugged with moderate force but it doesn't want to come out. What is the trick?
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.”
Ronald Reagan -
hotlap is offline   Reply With Quote
Old 05-09-2015, 11:27 AM   #2
hotlap
hotlap's Avatar
Ronald Reagan -
Old 05-09-2015, 12:55 PM   #3
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
There are specific terminal tools needed to properly remove and crimp on a new one. The GM shop manual designates which tool is needed. You can sometimes determine an alternative if you have a new terminal available for inspection of the side barbs that retain the terminal
Some load from the front, most from the back
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 05-09-2015, 02:03 PM   #4
97ChameleonTA
97ChameleonTA's Avatar
Drives: 2013 ZL1 Convertible
You have to go in from the plug side and bend a plastic lock out of the way. It's only about a 1/16th of an inch wide. If you don't have the tool a very small flat head screw driver will work.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15
FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's
New times to come with E85
2016 2SS Auto - Hyper Blue Metallic
Roto-Fab CAI
97ChameleonTA is offline   Reply With Quote
Old 05-09-2015, 02:43 PM   #5
winterboy8
winterboy8's Avatar
Drives: 2015 ZL1 Blue Velvet Metallic
If you can't find proper extraction tool, you can splice it. Get a solder butt-splice with attached wire and the you can cut the wire and solder in (most likely just need to heat depending on splice) it in and the you have you're wire to run to destination.
Search Raychem for the splices.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
winterboy8 is offline   Reply With Quote
Old 05-09-2015, 03:07 PM   #6
Mean Green Z28
Drives: 2010 2SS
if you cant get it out, use a wire stripper to cut into the jacket in two spots about half inch apart (don't hurt the wire), then use a knife/blade to slit the area in between to remove the jacket, wrap the new wire around the area and solder and then wrap it up in some electrical tape .. tadaaaa!!!!
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 05-09-2015, 04:47 PM   #7
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
you need a weatherpack tool or small pick to release the little pin that is retaining the wire...you can also strip the wire and solder as described in the post above
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-09-2015, 06:24 PM   #8
hotlap
hotlap's Avatar
Thanks for the advice guys. Where I work they do this sort of think regularly to interface onto truck chassis so I'll see about an extraction tool from there. If not I'll do like Mean Green suggests and wrap with tape. The only reason to pull the pin is to put a shrink wrap on it.
I tried to manipulate it with a small screw driver but am to worried about damaging it.
Ronald Reagan -
