Old 05-09-2015, 03:00 PM   #1
Greene Meanie
Greene Meanie's Avatar
Drives: 2011 Synergy Green 1LT CAMARO
Lucas Upper Cylinder Treatment - does it help or hurt?
With our Cars being DI does Lucas Upper Cylinder Lubricant help or hurt your mpg. The reason I ask is I have been using it consistently for the last 6k miles and my MPG has gone down from 29 to 26 even 24 on hills. I am starting to wonder if this is hindering my LLT ' S MPG. Any other input or facts would be greatly appreciated.
SYNERGY GREEN 1LT JBA Shorties - AIRAIDE CAI - RX- Catch CAN- Elite Oil Seperator -FLOWMASTER AXEL BACK- VITESSE THROTTLE CONTROLLER - V-MAX ICEoLATER-Flat BACK RIMs- PLASTIC Dipped Emblems-....
Greene Meanie is offline   Reply With Quote
Old 05-09-2015, 07:40 PM   #2
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
I am not a believer in "miracles" in a bottle.
Dimitrim is offline   Reply With Quote
Old 05-10-2015, 03:16 AM   #3
fly2hip8
Drives: 2013 Camaro 2SS
snake oil comes to mind
fly2hip8 is offline   Reply With Quote
Old 05-10-2015, 06:27 AM   #4
ChrisBlair
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3
Nothing is truly a tune up in a bottle. That's marketing mumbo-jumbo. However various products that clean injectors etc can have a beneficial effect without being a sham. Back when you could easily buy tetraethel lead suspended in kerosene by the bottle for example, it absolutely had the desired effect on my old engines that were made to run on leaded gas.
In order to asses the effects on your car, I'd suggest reviewing the parameters of your testing. My guess is it was not controlled very much, it's simply a time/distance comparison, you've used the product for X miles over Y months. Your decreased gas mileage can have a whole lot of reasons which do not need this product in order to have taken place.
Easiest path: stop using it for the next 6K miles and see if your MPG goes back to normal.
ChrisBlair is offline   Reply With Quote
Old 05-10-2015, 10:55 AM   #5
MrChrisLS3
Drives: 2018 1SS M6
My brother is a lead tech at a Cadillac dealership. He said that carbon build up on the back of the valves is pretty common for DI enignes. Remember, they are not getting cleaned by that shot of fuel in the runner.
The Lucas product, Seafoam, GM Top end cleaner, are all about the same, and do work for this application. Though, I'd probably go with the recommended GM product as it will be spec'd to go along with the rest of the systems involved.
The real secret here, however, is that this should be part of regular maintenence. Clean it before it effects performance. Possibly right before every other oil change. And follow directions, you don't want to hydrolock a cylinder.
MrChrisLS3 is offline   Reply With Quote
Old 05-10-2015, 11:17 AM   #6
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
Might want to test your effect the throttle controller is having on your MPG. I noticed mine has been worse since installing mine. I should scale back mine but I really like it set on 9!
its a syn is offline   Reply With Quote
Old 05-11-2015, 06:17 PM   #7
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
I would recommend the Seafoam induction treatment combined with Seafoam in the tank.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-12-2015, 10:28 AM   #8
revived
Vrrrm.
revived's Avatar
Drives: 2011 2SS/RS LS3
I wouldn't use any treatment period, if anything physically pull your injectors and clean them out rather then throwing the stuff in the gas tank. Sadly enough carbon is very difficult to remove with solvents in gasoline.
revived is offline   Reply With Quote
Old 05-12-2015, 11:09 AM   #9
MrChrisLS3
Drives: 2018 1SS M6
Agree, fuel treatment isn't the answer simply because it's not the problem. The problem is carbon build up on the back of the valves and valve stems.
Old 05-12-2015, 01:17 PM   #10
revived
Vrrrm.
revived's Avatar
my bad didn't read through lol.
Old 05-13-2015, 12:11 PM   #11
MrChrisLS3
Drives: 2018 1SS M6
Yeah, I guess I can't read either. lol
Didn't read that it was being used as a fuel treatment. Stop using it and see if MPG improves?
Old 05-13-2015, 07:06 PM   #12
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
I use their fuel injection cleaner treatment in my tank about once every 10 times I fill up, I never notice a difference in MPG in my Camaro but in a diesel truck I notice a big difference. Lucas makes some good products but obviously it can only do so much. How many miles on the LLT? And do you have a catch can?
TommyTheCat is offline   Reply With Quote
Old 05-13-2015, 07:13 PM   #13
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
I would also say it is the VTC. I have seen a 1.5 to 2 mpg drop. But it is so worth it. lol
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 05-21-2015, 07:34 PM   #14
Greene Meanie
I just installed a RX can about 500 miles ago. I went one tank without cleaner but scaled back my throttle controller to 0 from 7. My MPG is comming back. Think I found my problem.
