Old 05-09-2015, 05:39 PM   #1
chuckclanton
Drives: 2021 Camaro 2LT
Strut tower brace?
Do they really serve any useful purpose on a coupe?
chuckclanton is offline   Reply With Quote
Old 05-09-2015, 06:01 PM   #2
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Most data shows little to no affect.
That being said the factory piece is cheap, light, and good looking. It can't hurt.
I also figure it probably does "something" because GM is less than likely to put something on that has no use. They threw it on the Convertible, ZL1, 1LE and Z/28.
So my opinion is "maybe"... lol
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 05-09-2015, 06:05 PM   #3
Bizaro
Drives: 2015 Redhot 1LE
track use only where car might flex
Bizaro is offline   Reply With Quote
Old 05-09-2015, 06:20 PM   #4
habunow1
habunow1's Avatar
Drives: 2010 Yellow 2SS, 2011 CG 1LT IPF SC
I you drive the local streets like you are on the track.
habunow1 is offline   Reply With Quote
Old 05-09-2015, 07:27 PM   #5
chuckclanton
Wonder why strut braces are not mentioned in "5th Gen Suspension----The Book" ?
Old 05-09-2015, 08:54 PM   #6
Firefighter
Pete feels they are useless. He pretty much knows best. He covers it in some of his original info talking about the development of the 5th Gen.
I can't see it being a negative in any way. It literally weighs 2.5 lbs (guesstimate) and it looks good.
If I had a regular SS it would be the one of last things I bought.
Old 05-09-2015, 09:23 PM   #7
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
FWIW the first few days after I installed mine I heard a metal stressing type sound near the moon roof front, so I concluded it was result of the brace tighting the frame up some
camguynj is online now   Reply With Quote
Old 05-09-2015, 09:47 PM   #8
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
I remember when I first got the strut brace on before I did any suspension/handling, I noticed that it was more tight when turning on tight corners.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 05-09-2015, 11:15 PM   #9
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I put on the stock part. Looks nice and good place to rest your hand when cleaning things...lol Seriously I noticed less vertical movement up front when driving over patched asphalt so must do a little. In auto x I I couldnt tell really
VR Baron is offline   Reply With Quote
Old 07-24-2015, 08:33 AM   #10
FrostySS
FrostySS's Avatar
Drives: 2018 Redline Edition 2SS
When I put mine on I beat two Lambo's on the track and I had 35 virgins ask for dates....talk about results!
OK,not really. I don't think it did a thing, looks good though.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD.
FrostySS is offline   Reply With Quote
Old 07-24-2015, 08:38 AM   #11
luv_freedom
Drives: 2014 Camaro 2SS RS auto conv.
Needs to be polished
I like the looks of it. It makes my vert SS more aggressive looking, but it would look much better if it were polished. I'm going to check out places that might be able to do that for me.
luv_freedom is offline   Reply With Quote
Old 07-24-2015, 08:49 AM   #12
Firefighter
That's brilliant... LoL
Old 07-24-2015, 08:51 AM   #13
Firefighter
If you polish it will become an extra job to maintain it. There are several who have them painted. I just used some chassis black on my center section and left the ends natural. That fits in with my motif though.
Old 07-28-2015, 11:48 AM   #14
JusticePete
Drives: Camaro Justice
The brace was developed for tuning the MRC on the ZL1. The bar altered the harmonics allowing the engineers to collect more accurate data while tuning the MRC. In terms of function, it adds structure to the vert and the vert needs it. Cutting out the roof removes critical structure.
On street tires, a 5th Gen without a bar will turn in better. The slight flex allows for a dynamic camber change that improves turn in. Te Z/28 DSSV dampers have a very high zero point and the springs are much higher in rate. The trofeos are street legal slicks. The bar helps work the very soft tread of the trofoes.
Those of you on street tires and much softer springs and damping, the strut tower bar looks cool.
This client has been racing for over 30 years. His thinking is that the firewall functions as the strut tower bar behind the struts and the his Z/28 needed a bar in front of the struts so he made one.
