Old 05-09-2015, 09:12 PM   #1
BLK MARO
BLK MARO's Avatar
Drives: 2013 1SS/RS CAMARO
LG coilover problem
Im getting a hard clunk noise in the back when I hit a decent sized bump either going fast or slow. You guys have any ideas what the problem is? Im thinking it might be the spring. don't know
BLK MARO is offline   Reply With Quote
Old 05-11-2015, 09:34 AM   #2
Mike_G
Drives: 2010 2SS/RS
Did this happen after instal or something that just came up? nI had a clunking on one side in the rear and after talking with anthony it turned out to be the spring rubbing on the body of the car during compression. Check for any rubbing marks on the first couple coils at the top to rule this out. If you see any marks on the coils, the upper spring mount can be moved to give more space. The holes in the upper mount are slotted which gives lots of adjustability. On mine I adjusted so the area of the spring that had rub marks had more clearance and no more noise.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs....
Use to have
2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's
Mike_G is offline   Reply With Quote
Old 05-11-2015, 07:06 PM   #3
BLK MARO
BLK MARO's Avatar
It happen right after install. ill check the springs to see if theres rub marks. thanks for the reply! ill be sure to update you
Old 05-11-2015, 11:31 PM   #4
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
If the spring is not rubbing, check the swaybars...i lowered mine too much and the swaybar was hitting the frame...
13blackLS is offline   Reply With Quote
Old 05-14-2015, 12:03 AM   #5
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Check this link; http://www.camaro5.com/forums/showth...=385590&page=6
I have a set and I'm wondering if they are worth installing. I have Hotchkis 1" drop springs with full suspension upgrades right now. My biggest concern is ride quality. Any info would be appreciated.
SS PANTHER is offline   Reply With Quote
Old 05-15-2015, 04:20 PM   #6
BLK MARO
BLK MARO's Avatar
thanks for the link! im taking my car to raymonds next to week to have them install my exhaust cutouts. im going to have them look at the rear and see whats going on back there.
