Old 05-11-2015, 01:34 PM   #1
M0dnar
Drives: 2015 Corvette 3LT with Z51
Factory 18" Steelies and SS Brembos
Does anyone know if the factory 18" heritage wheels that come standard on the 1LS clear the SS Brembos? Or should I order some spacers just in case?
M0dnar is offline   Reply With Quote
Old 05-11-2015, 06:09 PM   #2
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I'm pretty sure they don't.
Jenner is offline   Reply With Quote
Old 05-11-2015, 06:54 PM   #3
M0dnar
Well the good news is the new 18" wheels I bought should fit. At least TireRack will sell it if I set my car to a Camaro SS. Guess I'll just have to put off my brake swap until I get my new tires in...
Old 05-11-2015, 07:19 PM   #4
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
Yeah I read hay with the right offset 18"s will work, just not the stock LS ones.
Old 05-11-2015, 07:46 PM   #5
M0dnar
I think with the brake swap it's more how the heritage spokes/surface is designed rather than offset. Going to call TireRack to confirm that the 18" wheels I bought will actually fit on a SS, but if it does then that wheel technically loses 3mm of offset, but it's got a much thinner edge than stock. Worst case do you know how wide of a spacer I can get and still be safe on the track? Or does spacer thickness not degrade performance?
Old 05-11-2015, 08:11 PM   #6
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I was told 3-5 MM is safe. Idk if it changes with wheel size or things like that
