Old 05-11-2015, 02:41 PM   #1
kyle@ridetech.com
kyle@ridetech.com's Avatar
Drives: 1969 SS/RS Camaro
Tin Sign Giveaway
I've decided to do a little contest on here. Post a picture of your car and list the suspension mods. Don't worry, if yours is stock you're still eligible. I'll draw a winner at random each time the post count for this thread hits 100. I'll go ahead and start it off.
Ridetech Level 2 CoilOver system with Tru-Turn and front MuscleBar.
kyle@ridetech.com is offline   Reply With Quote
Old 05-11-2015, 02:47 PM   #2
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
2015 Camaro SS/RS/1LE... stock for now...
sherob is offline   Reply With Quote
Old 05-11-2015, 03:30 PM   #3
tgreen22
Drives: 2014 2SS/1LE
Stock but have the Ridetech HQ CoilOver to install when the wife isn't looking!
tgreen22 is offline   Reply With Quote
Old 05-11-2015, 04:37 PM   #4
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Everything Ride Tech has for a 5th Gen...
So Cal Camaro is offline   Reply With Quote
Old 05-12-2015, 04:13 PM   #5
bigblockz8
bigblockz8's Avatar
Drives: 2012 Camaro 2LS, 05 Trailblazer LS
My baby, also stock for now...Unless 600lbs in the trunk counts as a rear lowering mod.
bigblockz8 is offline   Reply With Quote
Old 05-12-2015, 04:52 PM   #6
BLU DUCE
BLU DUCE's Avatar
I have the 1 in. Hotchkins drop all around.
Old 05-12-2015, 04:56 PM   #7
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
My mods are:
-Pedders XA Coilovers
-Hyperco 8" 450 lb/in front springs
-Moreno Motorsports camber/caster plates
-1LE 27mm rear sway bar
-1LE toe rods
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out!
Burt is offline   Reply With Quote
Old 05-12-2015, 05:04 PM   #8
LStick
Drives: 2021 Shadow Gray 1LS
The '13 just like she came off the assembly line.
LStick is offline   Reply With Quote
Old 05-12-2015, 06:27 PM   #9
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
2014 SS. Stock for now.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 05-12-2015, 10:22 PM   #10
Johnnyrod
Johnnyrod's Avatar
Drives: 2010 ecs SS
'10 SS. BMR Toe rods, Trailling arms, cradle bushings.
Johnnyrod is offline   Reply With Quote
Old 05-12-2015, 10:44 PM   #11
760bowtie
760bowtie's Avatar
Drives: 2014 1SS/RS, 2018 Silverado CC
BMR lowering springs.
AGP 57/57 turbos and Dual Pump System, NA Cam, McLeod RXT clutch, MGW shifter, ZL1 Rear End, BMR Trailing Arms/Toe Rods, Pegasus Solid Cradle Bushings 10.7 @140mph M6
760bowtie is offline   Reply With Quote
Old 05-13-2015, 05:08 AM   #12
Javier_Montanez
Javier_Montanez's Avatar
Drives: 2011 Camaro LT with V6
2011 2LT with Eibach Pro-System Lowering Kit.
Javier_Montanez is offline   Reply With Quote
Old 05-13-2015, 10:14 AM   #13
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Stock for the most part suspension wise, couple of appearance mods.
BigBlock69RS is offline   Reply With Quote
Old 05-13-2015, 10:16 AM   #14
BigBlock69RS
Ed
Everything under the paint non-stock
