Old 05-11-2015, 04:58 PM   #1
Keachj06
Keachj06's Avatar
Drives: 15 SS,13 Duc Panigale
The GM Recall on the key fob
bought a 2015 SS, I received two keys both are obviously the half assed GM's solution to the infamous I am giving birth to my steering wheel and knock the key out problem. I want to make my 2015 key set a switchblade style, looks like all I need to do is destroy the plastic piece holding my key in with a dremel remove it and place it where it belongs by drilling in to it and securing it in place with a roll pin. easy enough, however my question is if I dremel this damn key is the PATS system inside my transponder or is it inside the plastic housing for the key? I know my old POS ford had the transponder inside the key housing and not the transponder.
Keachj06 is offline   Reply With Quote
Old 05-11-2015, 05:03 PM   #2
Ragnar
Destroyed by flooding
Ragnar's Avatar
Drives: Wife's car
You'll be ok, it is in the FOB and not the plastic housing for the key.
Old 05-11-2015, 05:22 PM   #3
Punisher80
Drives: 2015 Camaro 2SS 1LE
I also have a 2015, did mine yesterday and everything worked just fine today.
Punisher80 is offline   Reply With Quote
Old 05-11-2015, 05:26 PM   #4
Keachj06
Keachj06's Avatar
thanks for the confirmation looks like I got a project to do.
Old 05-11-2015, 05:45 PM   #5
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
Where can you get the rolling pin from?
zr1chris is offline   Reply With Quote
Old 05-11-2015, 05:50 PM   #6
WymanD
BackNBlack
WymanD's Avatar
Drives: 2015 Camaro
...subscribed, ..need to find out how to do this myself for my 2015 keys..
WymanD is offline   Reply With Quote
Old 05-11-2015, 06:05 PM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
There is a security chip in the new key, that is why they need the car when they do the recall, they need to program the new chip to work in the car and they are supposed to disable the one in the fob at the same time.
I just went out and with the fob in my house I took the key and started the car, drove up the road, shut the car off, then restarted it and drove back home. If there was no chip in the key I would not have been able to do that.
If you switch the key back to the fob then you will need reprogram the fob to work again unless your dealer didn't disable the fob security.
The Bird is the word!
Old 05-11-2015, 06:12 PM   #8
Keachj06
Keachj06's Avatar
I assume from a hardware store I mean I was able to pick a few up when assembling my AR Lower for the takedown pins. I mean those roll pins are a bit bigger and didn't look for the smaller ones but I would imagine they have all sizes.
Old 05-11-2015, 06:13 PM   #9
Keachj06
Keachj06's Avatar
true story, I ll try that out tomorrow when I get home and see if it works or not.
Old 05-11-2015, 06:24 PM   #10
Angrybird 12
Unless they did something different on the ones coming direct from the factory with the separated fob I can't confirm that, I just know what they did to mine on the recall.
Old 05-11-2015, 07:55 PM   #11
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Been through that with the dealer. Not taking the switchblade key.
Whoomba is offline   Reply With Quote
Old 05-11-2015, 08:02 PM   #12
zr1chris
zr1chris's Avatar
Guess I'll have to check my local Home Depot.
Old 05-12-2015, 05:45 AM   #13
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Even better: go to a real hardware store.
Rock-It Man is offline   Reply With Quote
Old 05-12-2015, 06:46 AM   #14
Angrybird 12
Those are getting very hard to find any more, Lowes and Home Depot have run most of them out of business.
