Old 05-12-2015, 04:34 AM   #1
gnturboray
gnturboray's Avatar
Drives: SIM 2010 2SS/RS LS3 LPE750
Catch can filling up fast
I've recently installed new Holley valve covers on my LS3. The motor is cammed with a Maggie with full supporting bolt-ons and 660rwhp. On first drive I noticed I was getting a lot of white smoke. I pulled the air intake tube and saw a lot of fresh oil pooled at the bottom of the throttle body. (Prior to me changing valve covers I never had an issue).
I picked up a new Elite Catch can and installed it on the drivers side. The intake hose is attached from the back of the drivers side valve cover to the elbow on top of the can and the outlet is attached to the drivers side of the supercharger inlet per the instructions.
I've driven the car twice since the can install for a total of about 60 miles. Each time a huge cloud of white smoke fills the area on cold start-ups. I was told that it might take a while for the oil to get out of the system. After tonight's trip I let the motor cool down and again pulled the air intake tube and the throttle body still had pooled oil in it. I opened the catch can and it was FULL!!
What gives? Is this normal? If not what are my solutions?
Please help, thanks.
gnturboray is offline   Reply With Quote
Old 05-12-2015, 05:56 AM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Sounds like those new Holley valve covers do not have an effective baffle installed in the area of the port and oil is being vacuumed from the valve cover port into the catch can and then into the supercharger. Pull the drivers side valve cover and compare the baffle, if one is installed, to the stock valve cover.
Just livin' life
2SSCAMARO is offline   Reply With Quote
Old 05-12-2015, 08:33 AM   #3
Keachj06
Keachj06's Avatar
Drives: 15 SS,13 Duc Panigale
may sound stupid but when you installed your valve cover did you remove the hoses and maybe swapped em around with your catch can? installing em backwards will cause pressure surges and in turn blow oil right out.
Keachj06 is offline   Reply With Quote
Old 05-12-2015, 09:42 AM   #4
gnturboray
gnturboray's Avatar
The catch can was installed after the new valve covers and I followed the directions from Elite and confirmed my hose routing via Camaro 5.
Old 05-12-2015, 10:05 AM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
The problem is the Holley valve covers. They have a poor baffling system. I suggest going back to the OEM valve covers. I've seen this time and time again.
Best regards,
Tyler
888-308-6007
Old 05-12-2015, 10:52 AM   #6
kaseyb85
Keep Calm & Chive On
kaseyb85's Avatar
Drives: 2013 Camaro SS/RS CGM
I have the EXACT same setup and the exact some problem! I havent checked the intake and TB yet tho. But damn the Holley valve covers look good.
kaseyb85 is offline   Reply With Quote
Old 05-12-2015, 11:07 AM   #7
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Best regards,
Tyler
888-308-6007
I second that! Infact, we had so much excessive blow by on a 1LE it from those valve covers it was starting to get outta control.. Check how your carch can is piped in as well..
Nighthawk89 is offline   Reply With Quote
Old 05-12-2015, 12:13 PM   #8
kaseyb85
kaseyb85's Avatar
just like the instructions. Driverside valve cover to the top of the CC and side of CC to the blower. im just glad all that isnt going back into the motor
Old 05-12-2015, 12:52 PM   #9
gnturboray
gnturboray's Avatar
Thx guys, I took the car into 21st Century Muscle Cars this morning and they confirmed that it was indeed the Holley valve covers.
Old 05-12-2015, 01:01 PM   #10
kaseyb85
kaseyb85's Avatar
but they look soooo good.
Old 05-12-2015, 01:08 PM   #11
gnturboray
gnturboray's Avatar
IKR!! But my catch can fills up on every trip! They gotta go.
Old 05-12-2015, 01:09 PM   #12
JDP Sales
JDP Sales's Avatar
KCCO Brother!
Best regards,
Tyler
888-308-6007
Old 05-13-2015, 09:36 AM   #13
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Holley valve covers
I have the same covers and that happened to me on the first start up. Read on the instructions that you must put an inline PCV valve on since the stock covers already have it integrated. The instructions should tell you what they recommend. It is an inexpensive FRAM inline filter that you must install. No biggie. I have done this and absolutely no issues afterwards.
rforbes is offline   Reply With Quote
Old 05-13-2015, 09:38 AM   #14
kaseyb85
kaseyb85's Avatar
Got a pic of it?
