05-12-2015, 01:18 PM | #1 |
Drives: 2015 1LE Join Date: May 2015
Best tuner kit, SLP, Whipple, Edelbrock?
Looking for a PD tuner kit, I really like the look of the new SLP but I was told I need to buy the heat exchanger separately. If that's the case-it doesn't make it much of a deal.
Any suggestions? Any Whipples on the 14's and 15's-does the Whipple interfere with the hood? I need a kit that make 650-700 rwhp easily and have good IAT control. I'm open to upgrading the heat exchangers, coolant reservoirs and pumps but if it gets too crazy I'll just toss a ECS kit on it and call it a day. I can make 650-700rwhp with a centri in my sleep. I just like the look of the PD under the hood. TIA!!!! |
05-12-2015, 01:48 PM | #2 |
LSX Bumblebee
Why not a centri? PD's all have to watch for IATs, if you have to go PD do the Heartbeat
05-12-2015, 02:23 PM | #3 | |
Drives: All things Turbocharged Join Date: Dec 2010
05-12-2015, 05:08 PM | #4 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
HEARTBEAT SC. Written all over this thread.
05-12-2015, 08:06 PM | #5 |
After adding up all the cost to do a PD and keep the IAT's in check, I've decided on an ECS kit.
Can't beat the cost of that kit compared to the power it will put out! I'll post up results as soon as I get the car. |
05-12-2015, 08:56 PM | #6 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Take a look at the Kenne Bell too. I just put one on my car and I love it. And if you like the looks of PD blowers, the KB looks awesome under the hood.
05-12-2015, 08:59 PM | #7 |
Yep Follow the logic tree and centri or TT is all that makes sense.
05-13-2015, 01:32 AM | #8 |
Drives: 2014 1SS RS 1LE tvs2300 Join Date: Jun 2014
Heartbeat, no doubt about it. It was overpriced when I bought my SLP, otherwise that is what I would have.
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned |
05-13-2015, 08:09 AM | #9 |
Drives: 2011 2ss blk/wht strp Join Date: Oct 2014
This is my first Fi car. I went Whipple. that and a cam has me close to 7 at the wheels with 8psi. Not much noise if your looking for that. Just my experience. But i like no noise its a money maker. Mine is an 11 so hood clearance i have no clue.
05-13-2015, 12:58 PM | #10 |
Drives: 2015 1SS RS 1LE Join Date: Dec 2007
We have some tuner kits ( SLP Jackshaft ) for under 5K if you are interested. Same system as the jackshaft Maggie, just a different housing.
05-13-2015, 03:00 PM | #11 |
Drives: 1996 Camaro Z28, 2012 2SS/RS Join Date: Aug 2012
Are the new style SLP the same as the Heartbeat?
2012 2SS/RS IOM, LS3, Aftermarket Hurst shifter, IOM interior, Borla "S", 1 7/8 Big Flow headers, ADM Race cold air, BMR 1" lowering springs, SLP Supercharger, Custom Comp Cam, Fore Innovations twin pumps, Flex Fuel Sensor
05-14-2015, 12:05 PM | #12 |
Too much is never enough!
Last time I thought about going ECS because of cost....then AGP pm'd me an offer I couldn't refuse........Talk to them, you can get big time power on your stock block. Then later on, go forged and use the same turbo setup for over 1000whp, just turn up the boost...
05-14-2015, 12:12 PM | #13 |
05-14-2015, 05:33 PM | #14 |
