Camaro➎ moderator
P0008. TSB after warranty
Has anyone else had this issue after warranty has expired? It's a 2010 V6 and there is a TSB on the issue. NHTSA ID Number: 10055422
Trying to see if they will cover it under warranty since there was a TSB on this issue before warranty expired. ![]() ![]()
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
I thought the TSB was on the CTS chains up to yr 2009.
NHTSA ID Number: 10055422 is for 2014 GMC Acadia Description: GM: SOME DTC CODES MAY BE SET, P0016, P0017, P0018, P0019, P0008, OR P0009. 3.6 LY7 WITH CAM ACTUATOR DTC.THE RELUCTOR FOR THE CRANKSHAFT SENSOR PRESSED ON THE CRANKSHAFT MAY HAVE MOVED. ALSO INCLUDED BUICK ALLURE MODEL YEAR 2005. *JS GM rep on C5 says they handle this on a "case by case basis" so I would contact him.
Camaro➎ moderator
It looks like the camaro is included in it. That's what came up on the nhtsa website when I looked up camaro tsb.
really? did not see that.
Camaro➎ moderator
Has anyone had any luck getting this fixed by GM?
#6 |
![]() Drives: 2016 GT350 Join Date: May 2015
Just did chains on a 2012 with 48k, this problem doesn't seem to be going away.
"Life is hard, it's harder if you're stupid" John Wayne
#7 |
![]() Drives: 2010 camaro rs Join Date: Jul 2015
Having this problem as well. Any luck getting it taken care of after 100,000 miles.
#8 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
#9 |
here is my update.
I have a 2010 Camaro rs. I have the v6 and like pretty much all the v6s of this year I now have the dreaded p0008 code. now I will let you know I drive my car. (that is what it was made to do) it has 116k on it now. so I took it to my local dealership. and they tell me the same old story. about not knowing that this was a problem. mind you from my postion near the garage I can see a buick enclave getting timing chains installed. after a short time the manager comes to tell me that it is in fact the p0008 code and it will cost 2000 to fix. but my friendly service manager will see what they can do to help. after a short talk with customer service they got the bill down to 800. while I was waiting to hear how much they could help me I ask a local mechanic how much he would charge to do the job. he would do it for the magical number of 800. (crazy right). well im not a rich person not even close. 800 bucks is a lot of money for me, I assume it is a lot for most ppl. It kills me to know that chevy KNOWS THEY HAVE A PROBLEM. lets face it they know cause they extended other cars warranties WITH THE SAME MOTOR FOR THE SAME PROBLEM. the Camaro was one of the cars that helped chevy dig out of one of the worst times in us history for them. We all went out and bought one THEY WERE AWESOME. but as a customers I guess we are just crap. I have hundreds of thousands of miles on chevy products. but I think its time to look at a Chrysler product. I bet after I post this everywhere I still wont get any response or help |
#10 |
![]() Drives: Summit White 2012 1LT/RS Join Date: Dec 2010
I have just received the p0016 p0017 p0018 and p0019.. seems like the timing chain is stretched
2012 Summit White 1LT/RS
Cold Air Inductions CAI, VMaxx ported throttle body, RX catch can, Led Interior Lights, Led License plate lights, Hood Spears, Blacked Out Rear Trunk panel, Gills, Blacked Out Front Fascia, and Bow tie |
#11 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
#12 |
My LS3 oil pump went at 9800 miles and was basically told I was on my own due to being 2 months out of warranty. At 100k miles I wouldn't expect lube before they screw ya. Find a good mechanic, dealers suck.
Sent from my Pixel XL using Tapatalk |
#13 | |
![]() ![]() Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
If $800 is a lot (which it is) best get you some tools. GM told me to pack sand on the afm lifters and now i'm rolling with a BTR stage II VVT cam....
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
