Old 05-15-2015, 10:23 PM   #1
shotime
Drives: 2010 camaro 1ls
Battery or electrical issues.... help!
Hey guys i have a 2010 v6 today i drove for about 20 minutes no problems at all parked it went back out after about 2 hours to leave... went to start it all gauges turn on except i get a message "4 keys paired" try to start it and nothing... no clicks so i try to jump start it and have no problems, starts right up let it run for 15 minutes turn it off and back on starts up no problem... I had AAA come out as i am assuming i will need a new battery any way... they run a test on the battery results come back as "good" needs moderate charge. alternator was fine as well...... has any one had this issue before?
another problem I'm assuming is related to this my radio says "private call" and would not shut off even with car on off locked and waited about 40 minutes to see if it would time out but it never shut off. when I'm in my house and go to make a call it says its still connected to my bluetooth. the only way i was able to get my radio to turn off was to disconnect the negative cable on my battery...:thumb down:
any help on these issues would be greatly appreciated!
shotime is offline   Reply With Quote
Old 05-15-2015, 11:21 PM   #2
Sidecardog1
Sidecardog1's Avatar
Drives: 2015 2SS, 1LE, Dual Mode, Black
If you still have your original battery, that is probably your issue. Have the battery load tested and you should have your answer.
Sidecardog1 is offline   Reply With Quote
Old 05-15-2015, 11:26 PM   #3
shotime
Under a load it still came back as "good battery" however it is still the GM battery.... i bought the car used but i doubt any one would buy an oem battery
Old 05-16-2015, 01:11 PM   #4
Dimitrim
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1
Testing a battery with a load tester is the best way to check the condition of your battery. If it tested good with the load tester, it's not your battery. You have another electrical gremlin.
Dimitrim is offline   Reply With Quote
battery
