Old 09-04-2009, 05:55 PM   #1
Qwerty2
Drives: Black 2010 Camaro
Hydraulic clutch
I'm not sure if I like having the Hydraulic Clutch...It's much to soft and springy for me! And shifting into first gear is always jerky (for me and my family at least) unlike on the other clutches. Is there any way to change this??
Qwerty2 is offline   Reply With Quote
Old 09-04-2009, 05:57 PM   #2
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
First time i drove mine which was drive home from dealer, i HATED it. it grows on you quickly, my foot and leg learned it very quickly. I don't mind it now. Some people are taking a spring right below the peddle out and said its better, one person mentioned don't remove the spring but several people have done it. Practice Pratice Pratice, I would say the more i drive the more comfortable I get. First day was bad but never stalled it, almost 700 miles later feels like i been driving it forever.
jpsuperman81 is offline   Reply With Quote
Old 09-04-2009, 06:00 PM   #3
Qwerty2
Hmm, can you supply a link to that page about the spring? And I'm only at like 200 miles so it will probably get smoother.
Old 09-04-2009, 06:08 PM   #4
jpsuperman81
Yep I'm back!
I can't find it if i do I will post it.
Old 09-04-2009, 06:15 PM   #5
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
yea, the clutch grabs too hard or the pedal travel doesn't feel right? It seems that it grabs in a spot that almost stalls the car out and gives you a jerky launch sometimes, especially on hills at a light.
I'm a GM tech and have never felt this type of clutch. I think it travels too far before engaging. On a hill it seems like the car rolls back alot before the clutch starts to grab.(scary). I hate to ride the clutch anytime, but this car is hard to get use to. I'm not a newb to stick so its not that.
canadian ss is offline   Reply With Quote
Old 09-04-2009, 06:50 PM   #6
Dan3
Captain of the Failboat
Dan3's Avatar
Drives: 2010 IBM Camaro 2SS/RS
The clutch does grab hard. It's not an issue, just how its built, but I blame the spring.
The spring in question is located on the clutch pedal, up under the dash. If you look under there with a flashlight you can't miss it. Use a screwdriver to pry each side out of its hole and the spring comes right out. Removing it makes the clutch a lot smoother and takes a lot of the springiness out of it. It felt to me like the spring pulled hard right about the same location as the clutch engages, which made the clutch even grabbier. If you have issues with the clutch, I suggest taking the spring out. If you dont like the change, the spring pops right back in, no problem. I have yet to see anyone post anything saying this hurts the car, and being that it's hydraulic I don't see how it could hurt.
2010 Camaro 2SS - Imperial Blue w/Black Leather Interior
Ordered - 22 June 2009
Produced - 10 August 2009 : #34143
Delivered - 25 August 2009
Dan3 is offline   Reply With Quote
Old 09-04-2009, 06:56 PM   #7
BlkWolf
Drives: 94 Yukon 9" lift, 07 Civic SI
+1!!!!
I thought it was just me when I test drove it.
I wish it engauged earlier too. There's to much travel for my liking before the clutch enguages.
Is there any adjustment to change this or will removing the spring improve this?
Thanks
BlkWolf is offline   Reply With Quote
Old 09-04-2009, 07:34 PM   #8
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Originally Posted by BlkWolf View Post
+1!!!!
Thanks
I've owned several cars and trucks with wet clutches. The pedal spring should stay in place, that is a return spring. Normally there is two cylinders on the system. There should be the master, under the hood by the brake. Then there should be a slave on the trans itself. On the ones I've driven there was an adjustment screw to change the slave travel, so you can make changes to engage point.
Old 09-04-2009, 07:35 PM   #9
Bbrock25
Bbrock25's Avatar
Drives: 2010 1SS/RS Inferno Orange
I love how far you have to let out, doesn't bother me at all. But where the clutch engages is also where the clutch wants to push your foot on out. I took the spring out of mine, I can tell a noticeable difference in it, it won't push your foot out as hard, but you can still tell its there.
Link to the post for Clutch Spring Removal. Post #17
http://www.camaro5.com/forums/showth...spring+removal
Bbrock25 is offline   Reply With Quote
Old 09-04-2009, 08:15 PM   #10
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
dont most new cars have hydraulic clutches?
i have driven a few, and they are definitely different at first
levi1922 is offline   Reply With Quote
Old 09-04-2009, 08:18 PM   #11
Qwerty2
Thanks for the link, I'm going to try it out. Could removing the spring hurt the car?
And yes levi, most new cars do have the hydraulic clutch. But I feel like the Camaro's is to grabby, even for a hydraulic clutch.
Old 09-04-2009, 08:25 PM   #12
rodimus prime
Drives: Cargo van.
On this trans the slave is the throwout bearing. There is a bleeder on it, but Im not really sure you can adjust it. Just to get the air out of it. I belive you can adjust the clutch with a shim kit, but from the factory it shouldnt really need that.
rodimus prime is offline   Reply With Quote
Old 09-04-2009, 08:29 PM   #13
Sstac
Sstac's Avatar
Drives: 2010 2SS/RS Camaro
Is this the same clutch spring that is in the 2003 vette?
Current: 2010 Camaro CGM 2SS RS Manual
Past: '99 camaro, '01 Z28, '03 vette '08 BMW 535i
1100, Preliminary order accepted 08-06-09
2000, Accepted By GM
09-1-09
3000, Order accepted by production control 09-1-09 TPW 09-21-09
3300, Order scheduled for production 09/11/09
3400, Order broadcast 09-12-09
3800, Order produced 09-22-09
4000, Available to ship 09-23-09
4200, Shipped 09-24-09
5000, Delivered to the dealer 10/12/09
* Picked up 10/12/09
Sstac is offline   Reply With Quote
Old 05-17-2012, 07:50 AM   #14
Vespula2012
Vespula2012's Avatar
Drives: 2012 Camaro RS/SS LS3
I'm also having a difficult time getting used to this clutch! I just traded in my 2008 Mustang GT for a 2010 Camaro SS, but this clutch is killing me!
Its like the clutch pedal has 7 inches of overall travel but is fully engaged in only 1 inch of it, and just as others have said, that 1 inch of engagement happens right when the spring is pushing hardest against your foot.
I'm finding it very difficult to make a smooth start and even shift smoothly between gears sometimes. Its especially bad when you're on a hill or caught of guard when the light changes and you have to react quickly.
The pedal moves exactly like a compound bow... harder to push for the first half of the travel, then suddenly easy as can be (though none of the travel is actually hard... just relatively speaking). But the worst part is, that 1 inch of engagement travel occurs EXACTLY at the transition point.
If you want to get a good sense of it, go to any Walmart or sporting goods place and ask to see a compound bow. Then see if you can smoothly move it back and forth throughout its draw... see that sudden snap in the middle? That's exactly what its like.
I see some mentioning the spring removal and I'm sorely tempted to try this. Others have said its the return spring (which logically makes sense to me) but if that's true and the spring were removed, what would make the pedal travel back upward? Is it just counter pressure in the hydraulic system at that point or are you relying on the pressure plate or...?
Maybe someone can make an aftermarket piece to widen the range of engagement and remove that especially springy spot in the center? (please please please)...
Vespula2012 is offline   Reply With Quote
clutch, hydraulic
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
Coming Soon! RAM Twin Disc Clutch and Flywheel! Taking Pre-Order List @BMC Peformance Kris@BMCPerformance V8 Bolt-Ons & Tunes 7 02-18-2010 08:00 PM
Vengeance Racing Introduces RPS Organic Street Twin Clutch for 2010 Camaro!!! Ron@Vengeance V8 Bolt-Ons & Tunes 2 08-05-2009 02:03 PM
Burned my clutch a bit with Launch Control.... Caution you guys... Embalmer 5th Gen Camaro SS LS LT General Discussions 49 04-23-2009 09:49 PM
Cable or Hydraulic actuated Clutch ?? dougmac 5th Gen Camaro SS LS LT General Discussions 15 03-24-2009 11:51 AM
