Old 05-18-2015, 04:10 PM   #1
BLKRS2011
1LT RS 2011 BLACK
BLKRS2011's Avatar
Drives: 2011 1LT RS
Question MOD rear diffuser?
I just bought dual tips for MRT v2. Is it possible to just cut bigger outlets in the diffuser for the dual tips to fit thru? I thought I found a cheap solution for quad tips on my V6 but I don't want to spend all that $$$ on a brand new diffuser.
BLKRS2011 is offline   Reply With Quote
Old 05-18-2015, 04:41 PM   #2
Fieryfight
Fieryfight's Avatar
Drives: 2011 Camaro 2LT IBM Convertible
Its possible... but unless you are extremely good its going to look extremely ghetto. I looked into doing the same thing your talking about before deciding that $100 to get a 1le diffuser was worth the money.
...........................................2011 2LT IBM Convertible
Fieryfight is offline   Reply With Quote
Old 05-18-2015, 05:00 PM   #3
BLKRS2011
1LT RS 2011 BLACK
BLKRS2011's Avatar
Drives: 2011 1LT RS
The cheapest I can find the 1LE diffuser is $200 on ebay. Might have to bite the bullet but that's a lot for a piece of plastic. Thanks for the reply.
Old 05-18-2015, 05:02 PM   #4
Fieryfight
Fieryfight's Avatar
http://www.camaro5.com/forums/showthread.php?t=285088
I purchased mine through gmpartsdirect for around $100 plus shipping and you just take off the old diffuser and the 1le diffuser mounts right up without any modification
Old 05-18-2015, 05:06 PM   #5
hkittrell
hkittrell's Avatar
Drives: 2015 Camaro 1SS/RS 1LE
Does that thing come off super easy? Looked like four screws, just snap it out?
hkittrell is offline   Reply With Quote
Old 05-18-2015, 05:08 PM   #6
Fieryfight
Fieryfight's Avatar
6 screws and some tabs here is a write up on how to remove it
http://www.camaro5.com/forums/showthread.php?t=153221
the 1le diffuser mounts right up to it without modification
Edit: wasn't paying attention to who I was replying to... I am not sure about the 2015 model diffusers but the 2010-2013 models which the OP has are simple
Old 05-18-2015, 05:25 PM   #7
BLKRS2011
1LT RS 2011 BLACK
BLKRS2011's Avatar
Drives: 2011 1LT RS
I just ordered mine from GMpartsgiant.com for $116 delivered!
Old 06-19-2015, 12:08 AM   #8
Fieryfight
Fieryfight's Avatar
Did you ever get your exhaust finished?
