Old 05-19-2015, 10:03 AM   #1
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Curbed wheel..
For some reason I can't enter use the search feature...so if this has been covered before..my apologies.
I'm forgoing the $160 mobile wheel repair for my wheel as the last "mobile pro" did a so so job and feel the repair is well within my ability curve.
Curbed...actually hit a loose piece of concrete on the road but it looks like curb rash. I read in a few websites that Bondo works well after cleaning, degreasing and sanding. JB Weld was also mentioned in a few articles.
Anyone have any alternatives? Also, what paint works best for touch up?
Area is a millimeter or deep 2 mm wide and 3 inches long
Thanks!
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 05-19-2015, 10:25 AM   #2
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
I'd personally take it to Todd at Rodgers. If you want to do it yourelf, the paint is GM 8555 black. This is where it gets tricky. Its always going to look shiny unless you clearcoat it with a 40 gloss, 60% flattener agent.
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 05-19-2015, 12:04 PM   #3
Banshee
Banshee's Avatar
Sounds like a plan...thats where I got 1LE from. Any rough idea on cost?
Old 05-19-2015, 12:13 PM   #4
LT1Zob
LT1Zob's Avatar
Mine was a warranty issue. The factory never painted/coated the lugnut holes on all four wheels, stayed completely silver. I dropped them off last winter and had all 4 redone. Todd actually flipped the 60/40 to 40/60 matte/gloss so mine look a bit more gloss than factory. Easier to keep clean too. I'm sure it's a reasonable price, never have gotten sticker shock at Rodgers service. If it's too much, they'll tell you "it's not worth it, don't waste your money". I'm sure it's less than the $160 you paid before per wheel.
Old 05-19-2015, 01:46 PM   #5
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
Wait...you painted the lug-nut SEATING AREA???????????????????? Gulp...ok, good luck with that. Word of advice, carry a stick (tourque wrench) in your trunk. Just so you know, I spent 2 hours REMOVING the paint from the seat area.
backeddy is offline   Reply With Quote
Old 05-19-2015, 02:08 PM   #6
Banshee
Banshee's Avatar
So...Todd will fix the scrape damage and paint them? My wheels have the same issue with the paint not being even..can see the uneven hue with silver bleed.
Old 05-19-2015, 02:16 PM   #7
LT1Zob
LT1Zob's Avatar
"Seating part" is cleaned out after painting.
Old 05-19-2015, 02:26 PM   #8
backeddy
Banned
OK, just making sure! you would not have been the first one to have done this here. I will consider my comment null/void for YOU!
Old 05-19-2015, 02:29 PM   #9
backeddy
Banned
Also OP I have found that a 80/20 bondo/jb weld to be a pretty tough filler to beat (Higher % of JB is hard of sanding issues)
Old 05-19-2015, 04:47 PM   #10
Punisher80
Drives: 2015 Camaro 2SS 1LE
Matte black plastidip, the paint job on the rims is not very good, so the plastidip is an easy stop gap till you decide to get the rims all redone in powdercoat.
Punisher80 is offline   Reply With Quote
Old 05-20-2015, 07:43 PM   #11
GIDIUP
GIDIUP's Avatar
Drives: 2014 Red Hot 1LE
Sharpie works well until you get it painted. I have a few spots and use a sharpie. Pot holes.
It works for the time being. When I put her away for the winter I'll take the wheels to Wheels of America. I've seen there work here in Chicago and it's unbelievable.
GIDIUP is offline   Reply With Quote
Old 05-23-2015, 10:29 AM   #12
Kendall421
Drives: 1969 Z28, 1982 Z28, 2014 SS/RS/1LE
http://www.awrswheelrepair.com
http://www.foreinnovations.com/product_p/pen_black.htm
AWR does great repair work. Or you can sand the spot a little and use the black anodized paint pen and touch it up yourself.
Kendall421 is offline   Reply With Quote
Old 05-23-2015, 11:03 AM   #13
joshxjosh
joshxjosh's Avatar
Drives: Black 2014 2SS 1LE
Can you post pictures of the rim with the sharpie? I was thinking this as well but, obviously, was skeptical.
Kooks 1 7/8" LT Headers w/ no cats & NPP
joshxjosh is offline   Reply With Quote
Old 05-24-2015, 01:48 AM   #14
Banshee
Banshee's Avatar
Sharpie works...
Sharpie on a curbed wheel without sanding it first is like putting expensive makeup on a ugly woman
..from far away, looks ok.
The caveat? Sharpie would look better if the area was sanded down first.
