Old 09-04-2009, 09:43 PM   #1
Countach
Countach's Avatar
Drives: Future 2010 Camaro 2LT/RS
There is defiantly a problem with 2nd Gear
Did more runs with my car, i have 630 miles on it now and i wanted to do some more runs to see if i continued to have problems.
I have the auto and had it in sport tapshift mode
on the first run i had the gas down about 70-80% down.
First gear was fine shifted around 6k rpm
then i got into 2nd and got to around 5k rpm the engine began to stop and jump up the rpm latter. It stopped at 5k for a sec then jumped to 6k and then stopped again and jumped to 7k and i shifted. Each time it jumped it was very whiplash like. If anyone has driven a manual it was like shifting very un-smoothly. Except it did it 3 times in the same gear.
It did the same thing with TC off and with 100% throttle.
Im checking it out with my dad tomorrow morning, and probably taking it into service as-well. Anybody have any ideas of what this could be?
2LT/RS Auto with IO interior
1100 - 7/12/09 - NMGJKP
2000 - 7/20/09 - Order Accepted By GM
2500 - 7/22/09 - Order Preferenced
3000 - 7/23/09 - Order Accepted by Production Control TPW 8/17/09
3100 - 8/5/09 - Order Available to Sequence
3300 - 8/5/09 - Order Scheduled for Production
3400 - 8/12/09 - Order Broadcast
3800 - 8/19/09 - Order Produced 2G1FC1EV6A9137780
4200 - 8/20/09 - Order Shipped
5000 - 8/27/09 - Delivered to Dealer
6000 - 8/27/09 - Home
Countach is offline   Reply With Quote
Old 09-04-2009, 09:50 PM   #2
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
Maybe you hit the rev limiter
Icefsh is offline   Reply With Quote
Old 09-04-2009, 09:52 PM   #3
Countach
Countach's Avatar
the rev limiter is at 7k and does not kick in 3 times in the same gear b4 it even gets to 7k
Old 09-04-2009, 10:07 PM   #4
Icefsh
Icefsh's Avatar
In another thread it seems like someone was having a problem like this. his problem happened when the tach was at 6000. He also had an automatic. I think hitting the rev limiter was the consencise. I will try to remeber the tread. It was not to long ago.
Old 09-04-2009, 10:18 PM   #5
Countach
Countach's Avatar
yeah i was the one that made that thread, and its not the rev limiter
Old 09-04-2009, 10:21 PM   #6
Icefsh
Icefsh's Avatar
Sorry.
Old 09-04-2009, 10:37 PM   #7
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
something wrong with the torque management maybe?
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 09-04-2009, 11:21 PM   #8
BigBOSS
BigBOSS's Avatar
Drives: 2010 Camaro 1LT/RS, 6M, IBM
Why would you even be hitting 7k? The car looks like it is less than a week old
BigBOSS is offline   Reply With Quote
Old 09-04-2009, 11:25 PM   #9
Countach
Countach's Avatar
because 630 miles is enough to break in an engine
and i should be able to redline every gear and do burnouts out of the parking lot of the dealership with 10 miles on the car, this has nothing to do with break in
Old 09-04-2009, 11:42 PM   #10
Bumblebee10
Bumblebee10
Bumblebee10's Avatar
Drives: 2011 2LT Red Jewel RS Automatic
630 miles? huh? You probably broke the engine before it had a chance to break in. Chances are you might of killed the warranty since you didn't follow directions in the manual that says be careful for 1,500 miles.
Bumblebee10 is offline   Reply With Quote
Old 09-04-2009, 11:44 PM   #11
BigBOSS
BigBOSS's Avatar
Old 09-04-2009, 11:59 PM   #12
Countach
Countach's Avatar
do you have any idea how much engineering goes into the LLT engine?
Its an automatic transmission that shifts for you even if you are in tapshift mode if you get too high. If you think getting to 5-7k is dangerous for such an advanced engine that is tested and made to handle much higher rpm then i dont know what to tell you. If you just wanna say 1500 miles or else because the manual says so then please dont post in this thread
Old 09-05-2009, 12:20 AM   #13
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
My question would be, does it do it without using the tap shift and just in M and letting it shift on its own. Because it's my understanding once you hit one of the tap buttons, the computer goes into a different mode. Maybe you are bumping the limiter where the computer is giving you a shift denied until the RPM's are being matched.....Just a little safe guard ....
Old 09-05-2009, 12:25 AM   #14
Countach
Countach's Avatar
no it does it in sport non tap shift mode and in drive. The thing is it only happens in 2nd gear to my knowledge. It goes up the rpms very smoothly in 1st in tap shift mode. But it does has this problem in 2nd. I have not been able to test 3rd due to the speed but it seemed fine at 5k rpm when i shifted out of 2nd.
Using 6th gear? ladysman07 5th Gen Camaro SS LS LT General Discussions 33 08-17-2009 08:35 PM
Very faint clicking while in gear? Rusted Virtue Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-02-2009 11:42 AM
Twin Screw Supercharger and Gear Ratio usmcjlp Forced Induction - V8 2 06-27-2009 02:50 PM
Will the A6 start off in 2nd gear like the vette??? TomServo 5th Gen Camaro SS LS LT General Discussions 9 04-10-2009 10:41 AM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
